AI-2304-TT-24V-2-R
AI-2304-TT-24V-2-R
    PUIAUDIO
    BUZZER MAG 24V 23 X 17MM RADIAL
AI-2304-TT-24V-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 24 15 ~ 27 30 84 400 50 CONTINUOUS -20 ~ +65 -30 ~ +75 ABS Sn PLATED COPPER 8.5 Vdc Vdc mA dBA Hz 0 pulse /sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SPL, ROHS STATUS 5/29/2007 3/11/2008 9/23/13 B.R. M.L. C C grams 19 17 3.5 15.5 7.6 23 1 (2) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-2304-TT-24V-2-R.idw Designed by Date Checked by Date Approved by J.D. 5/29/2007 D.F. 5/29/2007 R.W. Date Drawn Date 5/29/2007 3/11/2008 AI-2304-TT-24V-2-R Indicator Edition Sheet - 1/1
AI-2304-TT-24V-2-R 价格&库存
很抱歉,暂时无法提供与“AI-2304-TT-24V-2-R”相匹配的价格&库存,您可以联系我们找货
