AI-4230-S-C24-R
AI-4230-S-C24-R
    PUIAUDIO
    DC Buzzer Single Tone 2.9kHz Piezo 1 ~ 28V 95dB @ 24V, 10cm
AI-4230-S-C24-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 24 1 ~ 28 15 93 2,900 500 CONTINUOUS -20 ~ +60 -30 ~ +70 NYLON Ni PLATED COPPER 5 Vdc Vdc mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR 2003, Projects Unlimited Inc. A B C D E DESCRIPTION DATE APPROVED RELEASED FROM ENGINEERING 5/18/2006 ADDED SNAP IN DIMENSION 11/21/2007 REVISED TO INVENTOR 3-D DRAWING TEMPLATE 3/6/2008 REVISED HOUSING MATERIAL TO ABS 8/9/2016 HOUSING MATERIAL CHANGED TO NYLON ON DATE CODE 18D 6/1/2018 AND AFTER REVISED WEIGHT AND SPL 2/24/2020 B.R. B.R. M.V. M.V M.V. C C grams 7 9 6 10 3 42 16 27 18 20.5 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-4230-S-C24-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 5/18/2006 E.P. 5/18/2006 B.R. 5/18/2006 3/6/2008 AI-4230-S-C24-R Indicator Edition Sheet - 1/1
AI-4230-S-C24-R 价格&库存
很抱歉,暂时无法提供与“AI-4230-S-C24-R”相匹配的价格&库存,您可以联系我们找货
AI-4230-S-C24-R
    • 1+27.49680
    • 200+10.64880
    • 500+10.27080
    • 1000+10.08720
