AI-2835-TF-LW150-3-R
    PUIAUDIO
    AUDIO PIEZO INDICATOR 3-28V CHAS
AI-2835-TF-LW150-3-R 数据手册
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 3 ~ 28 15 100 3,500 500 CONTINUOUS -20 ~ +60 -30 ~ +70 ABS LEAD WIRE 15 Vdc Vdc mA dBA Hz 0 pulse/sec REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED NOTE #4 REVISED RATED MAX CURRENT TO 15mA 10/11/2006 2/6/2008 12/5/2013 8/19/2019 B.R. B.R. M.L. 2003, Projects Unlimited Inc. C C grams 6 4 3 (2) 8 150 5 5 2 BLACK(-)/RED(+) UL1007 AWG #26 39.5 33.5 18 28 6 SOUND EMISSION HOLE 25 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. INTERNAL WIRES ARE UL1571, AWG#36 WITH A660 ADHESIVE OVER SOLDER JOINTS ON BENDER AND 504 ADHESIVE OVER SOLDER JOINTS ON PCBA. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . Designed by Date Checked by Date Approved by J.A.F. 10/11/2006 B.R. 10/11/2006 R.W. SIZE A3 AI-2835-TF-LW150-3-R Rev. C.idw Date Drawn Date 10/11/2006 2/6/2008 AI-2835-TF-LW150-3-R Rev. C Indicator Edition Sheet - 1/1
AI-2835-TF-LW150-3-R 价格&库存
很抱歉,暂时无法提供与“AI-2835-TF-LW150-3-R”相匹配的价格&库存,您可以联系我们找货
    • 1+32.87520
    • 200+12.72240
    • 500+12.27960
    • 1000+12.06360
