SMT-1324-TW-1V-R
SMT-1324-TW-1V-R
    PUIAUDIO
    Peak-Peak Signal Buzzer Single Tone 2.4kHz Magnetic 1 ~ 3V 80dB @ 1.5V, 10cm
SMT-1324-TW-1V-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNIT 1.5 1~3 30 15 3 80 2,400 500 -30 ~ +70 -30 ~ +85 NORYL Sn PLATED BRASS 5 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED TEMPERATURE SPECIFICATIONS 2/21/2006 6/2/2010 3/2/2020 B.R. M.V. mA OHM dBA Hz C C grams 13.1 6.5 2.2 WASH TAB _ + 12.5 2 2.2 SOUND EMISSION HOLE 11.3 12.5 EPOXY 3.7 6.7 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-1324-TW-1V-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.A.F. 2/21/2006 E.P. 2/21/2006 B.R. 2/21/2006 6/2/2010 SMT-1324-TW-1V-R Transducer (Electro-Mech) Edition Sheet - 1/1
SMT-1324-TW-1V-R 价格&库存
很抱歉,暂时无法提供与“SMT-1324-TW-1V-R”相匹配的价格&库存,您可以联系我们找货
