CEP-4411AC
CEP-4411AC
    CUIDEVICES
    AUDIO PIEZO IND 30-120V CHASSIS
CEP-4411AC 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 3 MODEL: CEP-4411AC | DESCRIPTION: PIEZO BUZZER INDICATOR FEATURES • wire leads with panel-mount tabs • 110 Vac rating • 2.8 kHz rated frequency SPECIFICATIONS parameter conditions/description min rated voltage max units 120 Vac/Vdc 7 mA 110 operating voltage current consumption typ 30 at rated voltage rated frequency 2,300 sound pressure level at 30 cm, rated voltage dimensions Ø41.8 x 22.0 2,800 Vac 3,300 88 Hz dB mm weight material ABS UL94 1/16” HB High Heat (black) terminal wire leads 22.2 g operating temperature -20 60 °C storage temperature -30 70 °C RoHS Notes: yes 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted. cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CEP-4411AC | DESCRIPTION: PIEZO BUZZER INDICATOR MECHANICAL DRAWING units: mm tolerance: ±0.5 mm wire: UL1007 LF 24AWG PERFORMANCE CURVES P: Voltage vs. Sound Pressure Level I: Voltage vs. Current Consumption cuidevices.com date 08/05/2022 | page 2 of 3 Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CEP-4411AC | DESCRIPTION: PIEZO BUZZER INDICATOR date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 09/22/2006 1.01 brand update 11/04/2019 logo, datasheet style update 08/05/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CEP-4411AC 价格&库存
很抱歉,暂时无法提供与“CEP-4411AC”相匹配的价格&库存,您可以联系我们找货
