AI-4329-P-SP28-R
AI-4329-P-SP28-R
    PUIAUDIO
    BUZZER PIEZO 12V 43MM PANEL
AI-4329-P-SP28-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 4 ~ 28 6 88 2,900 500 SLOW PULSE -20 ~ +60 -30 ~ +70 ABS Ni PLATED BRASS 43 Vdc Vdc mA dBA Hz 1.2 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED PULSE RATE UNITS REVISED TO INVETOR 3-D DRAWING TEMPLATE REVISED MOUNTING RING OUTER DIMENSIONS 2/14/2006 4/2/2008 4/10/2008 2/25/2020 B.R. B.R. M.V. 2003, Projects Unlimited Inc. C C grams 10.5 20 13 43 28 8.5 6.5 35.7 8 7.7 33 2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-4329-P-SP28-R.idw Designed by Date Checked by Date Approved by J.A.F. 2/14/2006 E.P. 2/14/2006 B.R. Date Drawn Date 2/14/2006 4/10/2008 AI-4329-P-SP28-R Indicator Edition Sheet - 1/1
AI-4329-P-SP28-R 价格&库存
很抱歉,暂时无法提供与“AI-4329-P-SP28-R”相匹配的价格&库存,您可以联系我们找货
AI-4329-P-SP28-R
    • 1+53.77320
    • 200+20.81160
    • 500+20.08800
    • 1000+19.72080
