AI-5025-TWT-R
AI-5025-TWT-R
    PUIAUDIO
    AUDIO PIEZO INDICATOR 5-13V TH
AI-5025-TWT-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 5 ~ 13 75 115 2,500 500 CONTINUOUS -20 ~ +60 -30 ~ +70 ABS PHOSPHER BRONZE 40 Vdc Vdc mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADD NOTE FOR C-PIN TRIGGER REVISED PIN MATERIAL 8/17/2005 3/11/2008 3/25/14 2/25/2020 B.R. M.L M.V. 2003, Projects Unlimited Inc. C C - 29 grams 10.4 REMOVABLE WASH TAB 50 22.5 7 2.8 11.25 0.5 (3) 20.8 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 20011/65/EC COMPLIANT. 4. C-PIN TRIGGER CURRENT @ 12Vdc is 2mA MAX UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-5025-TWT-R.idw Designed by Date Checked by Date Approved by J.A.F. 8/17/2005 B.R. 8/17/2005 E.P. Date Drawn Date 8/17/2005 3/11/2008 AI-5025-TWT-R Indicator Edition Sheet - 1/1
AI-5025-TWT-R 价格&库存
很抱歉,暂时无法提供与“AI-5025-TWT-R”相匹配的价格&库存,您可以联系我们找货
AI-5025-TWT-R
    • 1+71.02080
    • 200+27.48600
    • 500+26.52480
    • 1000+26.04960
