AW-10PR
AW-10PR
    PUIAUDIO
    DC Siren Pin Selectable Multiple Piezo 9 ~ 28V 88dB @ 24V, 100cm
AW-10PR 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE TONE OUTPUT CURRENT CONSUMPTION (NOMINAL) INGRESS PROTECTION CASE MATERIAL/COLOR TERMINAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 24 9 ~ 28 SEE 32 TONE CHART SEE 32 TONE CHART IP65 ABS/RED LEAD WIRE -10 ~ +60 95 Vdc Vdc THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING ADDED VOLUME CONTROL & TONE SWITCHES REVISED LEAD WIRE DIMENSIONS ADDED RoHS NOTE REVISED DETAIL "A" DIL SWITCH REVISED TO INVENTOR 3-D DRAWING TEMPLATE 12/21/2005 12/19/2006 12/20/2006 5/21/2007 3/11/2009 5/20/2010 R.W. R.W. R.W. B.R. B.R. mA C grams DETAIL "A" 45 1=CLOSED 0=OPEN 50 DETAIL "A" 13.5 DETAIL "B" VOLUME CONTROL 26 MAX DETAIL "B" BLACK (-) 200 5 NOTES: BLUE (-) RED (+) 3 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 2 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AW-10PR.idw Designed by Date Checked by Date Approved by J.A.F. 12/21/2005 E.P. 12/21/2005 B.R. Date Drawn Date 12/21/2005 5/20/2010 AW-10PR Siren Edition Sheet - 1/1
AW-10PR 价格&库存
很抱歉,暂时无法提供与“AW-10PR”相匹配的价格&库存,您可以联系我们找货
AW-10PR
  • 1+421.802331+54.81429
  • 12+322.0099912+41.84602
  • 28+294.8255228+38.31333
  • 52+276.7556752+35.96511
  • 100+259.14445100+33.67649
  • 252+257.66849252+33.48468
库存:223
