SPECIFICATIONS
PARAMETERS
RATED VOLTAGE (SQUARE WAVE)
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
5
3~7
50
47 7
85
2,400 500
-20 ~ +70
-30 ~ +80
PBT
Au PLATED
BRASS
2
Vpk
Vpk
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN
ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION
OF PUI AUDIO, INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
RELEASED FROM ENGINEERING
CHANGE VOLTAGE FROM Vpp to Vpk, UPDATE ROHS
2014/07/24
2019/05/16
M.L.
2010, PUI AUDIO Inc.
mA
OHM
dBA
Hz
C
C
grams
5.5
POTTING
REMOVEABLE TAB
2X
6.5
0.6
0.1
0.2
12
0.3
0.5
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2015/863/EU COMPLIANT.
9.5
0.3
UNLESS OTHERWISE SPECIFIED:
All PURCHASES ARE SUBJECT TO AND
INCORPORATE THE PUI AUDIO TERMS
AND CONDITIONS SALE FOUND AT
http://www.puiaudio.com
/pdf/terms_conditions.pdf
(paper copy available upon request).
DIMENSIONS ARE IN MILLIMETERS,
TOLERANCES ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AT-1224-TWT-5V-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
7/24/2014
C.W.
7/24/2014
R.W.
Date
Drawn Date
7/24/2014 7/24/2014
AT-1224-TWT-5V-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AT-1224-TWT-5V-R”相匹配的价格&库存,您可以联系我们找货
