AT-2429-TWT-R
AT-2429-TWT-R
    PUIAUDIO
    BUZZER PIEZO 12V 23.8MM RADIAL
AT-2429-TWT-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 2 ~ 30 8 70,000 30% 90 2,900 500 -30 ~ +105 -40 ~ +105 PPS Sn PLATED RED COPPER 5 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING REVISED TEMPERATURE RANGES REVISED TEMPERATURE RANGES REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED CAPACITANCE REVISED TEMPERATUERE SPECIFICATIONS 2/22/2006 5/28/2008 6/24/2008 9/30/2008 7/23/2018 2/28/2020 B.R. B.R. B.R. M.V. M.V. 2003, Projects Unlimited Inc. mA pF dBA Hz C C grams 6 23.8 16 5.7 SOUND EMISSION HOLE 15 0.8 (2) WASH TAB NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-2429-TWT-R.idw Designed by Date Checked by Date Approved by J.A.F. 2/22/2006 B.R. 2/22/2006 E.P. Date Drawn Date 2/22/2006 9/30/2008 AT-2429-TWT-R Transducer (Piezo) Edition Sheet - 1/1
AT-2429-TWT-R 价格&库存
很抱歉,暂时无法提供与“AT-2429-TWT-R”相匹配的价格&库存,您可以联系我们找货
AT-2429-TWT-R
  • 1+31.414171+4.08236
AT-2429-TWT-R
    • 1+11.46960
    • 200+4.43880
    • 500+4.28760
    • 1000+4.21200
