SMT-2225-T-R
SMT-2225-T-R
    PUIAUDIO
    BUZZER PIEZO 10V 22MM SMD
SMT-2225-T-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 10 1 ~ 30 Vp-p Vp-p 7 25,000 30% mA pF 80 2,500 500 dBA Hz C C grams -20~ +70 -30~ +80 NORYL Sn PLATED BRASS 2 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED DIAMETER OF PART UPDATE PARAMETERS ADDED NOTE 4 FOR MANUAL SOLDER ONLY 9/8/2006 11/8/2007 5/23/2012 8/31/2017 9/21/2018 B.R. J.D. M.L. M.L. 5.6 0.5 1.5 (2) 2.45 SOUND EMISSION HOLE 30.3 22 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. PART IS MANUAL SOLDER ONLY. REFLOW NOT ALLOWED. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-2225-T-R.idw Designed by Date Checked by Date Approved by J.D. 9/8/2006 B.R. 9/11/2006 R.W. Date Drawn Date 9/11/2006 11/8/2007 SMT-2225-T-R Transducer (Piezo) Edition Sheet - 1/1
SMT-2225-T-R 价格&库存
很抱歉,暂时无法提供与“SMT-2225-T-R”相匹配的价格&库存,您可以联系我们找货
