AI-2304-TT-24V-R
AI-2304-TT-24V-R
    PUIAUDIO
    AUDIO MAGNETIC IND 15-27V TH
AI-2304-TT-24V-R 数据手册
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 24 15 ~ 27 Vdc Vdc 30 84 400 50 CONTINUOUS -20 ~ +65 -20 ~ +70 ABS Sn PLATED COPPER 8 mA dBA Hz 0 pulse /sec REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING ADDED BODY DIMENSION REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED SPL, TEMP RATINGS, ROHS STATUS 5/24/2006 1/4/2007 12/19/2007 9/23/13 R.W. B.R. M.L. C C grams 17.5 17 3.5 7.6 14 22.5 1 (2) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-2304-TT-24V-R.idw Designed by Date Checked by Date Approved by J.D. 5/24/2006 E.P. 5/25/2006 B.R. Date Drawn Date 5/25/2006 12/19/2007 AI-2304-TT-24V-R Indicator Edition Sheet - 1/1
AI-2304-TT-24V-R 价格&库存
很抱歉,暂时无法提供与“AI-2304-TT-24V-R”相匹配的价格&库存,您可以联系我们找货
