SPECIFICATIONS
PARAMETERS
VALUES
UNITS
Vdc
RATED VOLTAGE
12
OPERATING VOLTAGE RANGE
8 ~ 15
Vdc
RATED CURRENT (MAX)
30
mA
MINIMUM SPL @ 10 CM
85
dBA
2,400 300
RESONANT FREQUENCY
Hz
0 pulse/sec
TONE OR PULSE RATE
CONTINUOUS
-20 ~ +70
OPERATING TEMPERATURE
C
STORAGE TEMPERATURE
-30 ~ +85
C
PA46
HOUSING MATERIAL
TERMINAL MATERIAL
Sn PLATED BRASS
grams
5
WEIGHT
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
E
F
RELEASED FROM ENGINEERING
UPDATED HOUSING MATERIAL
ADDED RoHS COMPLIANCE NOTE
ADDED NOTE 4
REVISED TERMINAL MATERIAL
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED STORAGE TEMPERATURE
10/13/2004
4/19/2005
8/10/2005
11/2/2005
3/20/2006
5/28/2010
2/27/2020
R.W.
B.R.
B.R.
B.R.
M.V.
13.1
12.5
6.5
2.2 SOUND
HOLE EMISSION
1.2 TYP.
2.2
12.5
2
REMOVABLE
WASH TAB
11.3
EPOXY
POTTING
3.7
1.2 TYP.
6.7
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
4. MAXIMUM REFLOW TEMPERATURE IS 260 C.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
SMI-1324-TW-12V-R.idw
Designed by
Date
R.A.C.
10/13/2004
Checked by
Date
Approved by
R.W.
Date
Drawn Date
10/13/2004 5/28/2010
SMI-1324-TW-12V-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMI-1324-TW-12V-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+61.638801+7.97400
- 10+47.8761010+6.19350
- 25+43.4921025+5.62640
- 50+40.3299050+5.21730
- 100+37.52710100+4.85470
- 250+35.77830250+4.62850
