AI-3736-P-C28-R
AI-3736-P-C28-R
    PUIAUDIO
    BUZZER PIEZO 12V 37.8MM PANEL
AI-3736-P-C28-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) MINIMUM SPL @ 10 CM RESONANT FREQUENCY TONE OR PULSE RATE OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 4 ~ 28 8 90 3,600 500 CONTINUOUS -30 ~ +80 -40 ~ +80 ABS Sn PLATED BRONZE 18.5 Vdc Vdc mA dBA Hz 0 pulse/sec THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED WEIGHT 5/22/2006 2/25/2008 2/24/2020 B.R. M.V. 2003, Projects Unlimited Inc. C C grams 19.5 4 37.8 31.5 36.5 4.8 8.5 1-64 x .156" SCREW (2) KNURLED NUT 8.2 23 2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. UNLESS OTHERWISE SPECIFIED: 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. DIMENSIONS ARE IN MILLIMETERS, 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AI-3736-P-C28-R.idw Designed by Date Checked by Date Approved by J.D. 5/22/2006 E.P. 5/22/2006 B.R. Date Drawn Date 5/22/2006 2/25/2008 AI-3736-P-C28-R Indicator Edition Sheet - 1/1
AI-3736-P-C28-R 价格&库存
很抱歉,暂时无法提供与“AI-3736-P-C28-R”相匹配的价格&库存,您可以联系我们找货
