SPECIFICATIONS
PARAMETERS
RATED VOLTAGE (SQUARE WAVE)
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNIT
3
2~5
Vp-p
Vp-p
35
mA
47
7
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
ADDED DETAIL VIEW OF TERMINAL LAYOUT
5/17/2006
11/7/2007
8/10/2011
B.R.
B.R.
OHM
dBA
Hz
-40 ~ +85
C
-40 ~ +85
C
PPS
Au PLATED BRASS
grams
2
80
2,000 200
0.15 MAX.
A ( 14 : 1 )
0.15 MAX.
9
REMOVABLE
WASH TAB
0.2
0.1
2
0.1
1.6
0.2
12
15.2
2.2 SOUND
EMISSION HOLE
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
EPOXY POTTING
A
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
SMT-1220-TW-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
5/17/2006
E.P.
5/18/2006
B.R.
Date
Drawn Date
5/18/2006 11/7/2007
SMT-1220-TW-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMT-1220-TW-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.746061+4.22297
- 10+26.5069910+3.31707
- 25+24.1426325+3.02120
- 80+21.4895180+2.68919
- 160+20.07187160+2.51179
- 320+18.76298320+2.34799
- 560+17.77946560+2.22491
- 1040+17.010421040+2.12868
