SMT-1028-S-5V-2-R
SMT-1028-S-5V-2-R
    PUIAUDIO
    Peak-Peak Signal Buzzer Single Tone 2.83kHz Magnetic 4 ~ 6V 93dB @ 5V, 10cm
SMT-1028-S-5V-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL VALUES UNIT 5 4~6 70 32 5 93 2,830 500 -40 ~ +85 -40 ~ +85 LCP (BLACK) Vpk Vpk WEIGHT REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING INCREASED OPERATING TEMPERATURE RANGE 05/11/2016 10/15/2018 M.V. mA OHM dBA Hz C C - GOLD PLATED BRASS 0.8 TERMINAL MATERIAL THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. grams 3.5 1 +Polarity 1 0.3 +Polarity +Polarity Sound Port Dummy Pads 8.8 Sound Port 3.6 10 -Polarity -Polarity -Polarity 2.1 6.4 1.5 1.4 10 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-1028-S-5V-2-R.idw Designed by Date Checked by Date Approved by T.E.S. 5/10/2016 C.W. 5/10/2016 B.R. Date Drawn Date 5/10/2016 5/10/2016 SMT-1028-S-5V-2-R Transducer (Electro-Mech) Edition Sheet - 1/1
SMT-1028-S-5V-2-R 价格&库存
很抱歉,暂时无法提供与“SMT-1028-S-5V-2-R”相匹配的价格&库存,您可以联系我们找货
SMT-1028-S-5V-2-R
  • 1+41.149391+5.34044
  • 10+31.4287010+4.07888
  • 25+28.3585025+3.68042
  • 50+26.2848150+3.41129
  • 100+24.39446100+3.16596
  • 250+22.14712250+2.87430
  • 500+20.61559500+2.67553
库存:3033
SMT-1028-S-5V-2-R
  • 1000+19.213911000+2.49362
  • 2000+18.377972000+2.38513
库存:3033
