This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2022, PUI Audio Inc.
Data Sheet
SMI-1027-TW-5V-R
Features:
• 5Vdc, 2700Hz magnetic indicator
Specifications
Parameters
Rated Voltage
Operating Voltage Range
Current Draw at Rated Voltage (Max)
Minimum SPL @ 10cm
Resonant Frequency
Tone or Pulse Rate
Housing Material
Terminal Material
Weight
Acceptable Soldering Methods
Environmental Compliances
Storage Temperature
Operating Temperature
Values
5
4~7
30
80 (typical 85)
2700 ±200
Continuous Tone
PPS
Tin Plated Brass
1.5
Reflow Solder
RoHS/REACH
-40~+85
-40~+85
Typical SPL and Current Draw Based on VDC Input
www.puiaudio.com
Units
VDC
VDC
mA
dBA
Hz
Grams
See page 2 for details
°C
°C
Recommended Soldering Procedure
One Reflow Cycle Only
Reliability Testing
Type of Test
High Temperature Test
Low Temperature Test
Test Specifications
96 hours at +85°C
96 hours at -40°C
Ten 24-hour cycles consisting of the following:
Temperature Cycle and Humidity Test
1. Continuous life test The part shall be subjected to 72 hours at +70℃ with
12VDC applied.
2. Intermittent life test A duty cycle of 1 minute on, 1 minute off, a minimum of
10000 times at room temp. (25±10℃) with 12.0VDC
Operating Life Test
applied.
After testing, the part shall be without any degradation in appearance or performance except
SPL. After 4 hours at +25°C, the SPL shall measure ±10 dBA compared to initial measurement.
www.puiaudio.com
Dimensions
Tolerance ±0.5 unless otherwise specified
Suggested Land Pattern*
*This land pattern is advisory only and its use or adaptation is entirely
voluntary. PUI Audio disclaims all liability of any kind associated with the use,
application, or adaptation of this land pattern.
www.puiaudio.com
Packaging
www.puiaudio.com
Revision
A
B
Specifications Revisions
Description
Released from Engineering
Updated Drawing
Note:
1.
2.
Unless otherwise specified:
A. All dimensions are in millimeters.
B. Default tolerances are ±0.5mm and angles are ±3°.
Specifications subject to change or withdrawal without notice.
www.puiaudio.com
Date
11/11/2014
11/8/2022
很抱歉,暂时无法提供与“SMI-1027-TW-5V-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+49.424351+5.94706
- 10+37.7600210+4.54353
- 25+34.0919825+4.10217
- 50+31.6041950+3.80282
- 100+29.33774100+3.53011
- 250+26.64256250+3.20581
- 国内价格 香港价格
- 600+24.34929600+2.92987
- 1200+22.705851200+2.73212
- 1800+22.396431800+2.69489
