SMI-1027-TW-12V-R
SMI-1027-TW-12V-R
    PUIAUDIO
    AUDIOMAGNETICIND7-15VSMD
SMI-1027-TW-12V-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Data Sheet SMI-1027-TW-12V-R Features: • 7 to 15 VDC voltage range with low 30 mA current draw • 2700 Hz tone for peak perception above ambient noise • Wide -40°C to +85°C operating temperature range Specifications Parameters Rated Voltage Operating Voltage Range Current Draw at Rated Voltage (Max) Minimum SPL @ 10cm Resonant Frequency Tone or Pulse Rate Housing Material Terminal Material Weight Acceptable Soldering Methods Environmental Compliances Storage Temperature Operating Temperature Values 12 7 ~ 15 30 85 2700 ±200 Continuous Tone PPS Tin Plated Brass 1.5 Reflow Solder RoHS/REACH -40~+85 -40~+85 Typical SPL and Current Draw Based on VDC Input PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Units VDC VDC mA dBA Hz Grams See page 2 for details °C °C This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Recommended Soldering Procedure One Reflow Cycle Only Reliability Testing Type of Test High Temperature Test Low Temperature Test Test Specifications 96 hours at +85°C 96 hours at -40°C Ten 24-hour cycles consisting of the following: Temperature Cycle and Humidity Test 1. Continuous life test The part shall be subjected to 72 hours at +70℃ with 12VDC applied. 2. Intermittent life test A duty cycle of 1 minute on, 1 minute off, a minimum of 10000 times at room temp. Operating Life Test (25±10℃) with 12.0VDC applied. After testing, the part shall be without any degradation in appearance or performance except SPL. After 4 hours at +25°C, the SPL shall measure ±10 dBA compared to initial measurement. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Dimensions Tolerance ±0.5mm unless otherwise specified Suggested Land Pattern* *This land pattern is advisory only and its use or adaptation is entirely voluntary. PUI Audio disclaims all liability of any kind associated with the use, application, or adaptation of this land pattern. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Packaging PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Revision A B Specifications Revisions Description Released from Engineering Added note to Reflow Solder Profile Updated Drawing Note: 1. 2. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. Specifications subject to change or withdrawal without notice. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Date 11/11/2014 6/27/2019 11/8/2022
SMI-1027-TW-12V-R 价格&库存
很抱歉,暂时无法提供与“SMI-1027-TW-12V-R”相匹配的价格&库存,您可以联系我们找货
SMI-1027-TW-12V-R
  • 1+45.763291+5.94706
  • 10+34.9629810+4.54353
  • 25+31.5666525+4.10217
  • 50+29.2631450+3.80282
  • 100+27.16457100+3.53011
  • 250+24.66903250+3.20581
库存:515
SMI-1027-TW-12V-R
  • 600+22.54564600+2.92987
  • 1200+21.023941200+2.73212
  • 1800+20.737431800+2.69489
库存:515
