CPT-3011C-120
CPT-3011C-120
    CUIDEVICES
    AUDIOPIEZOTRANSDUCER6-16V
CPT-3011C-120 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/05/2022 page 1 of 4 MODEL: CPT-3011C-120 | DESCRIPTION: PIEZO BUZZER TRANSDUCER FEATURES • externally driven • 104 dB SPL • 12 Vdc rated voltage SPECIFICATIONS parameter conditions/description min rated voltage 6 at rated voltage rated frequency sound pressure level at 30 cm, rated voltage at 300 cm, rated voltage dimensions Ø30.6 x 11.85 2,500 3,000 104 85 108 92 material ABS PA-777D terminal pin type operating temperature storage temperature Notes: units Vdc 16 Vdc 35 mA 3,500 Hz dB dB mm weight RoHS max 12 operating voltage current consumption typ 1.8 g -30 85 °C -40 95 °C max units 380 °C yes 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description min hand soldering for maximum 5 seconds 330 cuidevices.com typ Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CPT-3011C-120 | DESCRIPTION: PIEZO BUZZER TRANSDUCER date 08/05/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: ±0.5 mm Recommended PCB Layout Top View PERFORMANCE CURVE at 30 cm 120 115 110 105 100 95 90 85 80 P I 4 6 8 10 12 Voltage (Vdc) 14 16 DRIVING CIRCUIT Notes: 1. The current consumption and the sound pressure level are measured by using the recommended driving circuit shown above. cuidevices.com 20 15 10 5 0 18 Current Consumption (mA) Sound Pressure Level (dB) P: Voltage vs. Sound Pressure Level I: Voltage vs. Current Consumption Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPT-3011C-120 | DESCRIPTION: PIEZO BUZZER TRANSDUCER PACKAGING units: mm Outer Box Size: 310 x 248 x 49 mm Carton Size: 550 x 330 x 290 mm Outer Box QTY: 112 pcs per outer box Carton QTY: 1,120 pcs per carton cuidevices.com | PCB Footprint date 08/05/2022 | page 3 of 4 Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CPT-3011C-120 | DESCRIPTION: PIEZO BUZZER TRANSDUCER date 08/05/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 03/30/2016 1.01 changed packaging 08/15/2019 1.02 brand update 12/05/2019 logo, datasheet style update 08/05/2022 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CPT-3011C-120 价格&库存
很抱歉,暂时无法提供与“CPT-3011C-120”相匹配的价格&库存,您可以联系我们找货
CPT-3011C-120
    CPT-3011C-120
