CPT-1495C-300
CPT-1495C-300
    CUIDEVICES
    AUDIOPIEZOTRANSDUCER30V
CPT-1495C-300 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 4 MODEL: CPT-1495C-300 | DESCRIPTION: PIEZO BUZZER TRANSDUCER FEATURES • externally driven • wire leads • IP67 rated SPECIFICATIONS parameter conditions/description min typ operating voltage current consumption at 10 Vp-p, 4,250 Hz square wave rated frequency max units 30 Vp-p 12 mA 4,250 sound pressure level at 10 cm, 10 Vp-p, 4,250 Hz square wave electrostatic capacity at 1,000 Hz/1 V dimensions Ø14.0 x 10.0 84 14,000 dB 20,000 PBT+15% Glass terminal wire type 26,000 pF mm weight material Hz 2.60 g operating temperature -30 85 °C storage temperature -40 95 °C max units 380 °C RoHS yes IP level Notes: IP67 (IEC standard 529 edition 2.0 (1989)) 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description min hand soldering for maximum 5 seconds 330 cuidevices.com typ Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPT-1495C-300 | DESCRIPTION: PIEZO BUZZER TRANSDUCER date 08/05/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: ±0.5 mm wire: UL1007 LF 22 AWG FREQUENCY RESPONSE CURVE 100 90 dB 80 70 60 50 20 200 Hz cuidevices.com 2K 20K Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPT-1495C-300 | DESCRIPTION: PIEZO BUZZER TRANSDUCER PACKAGING units: mm Outer Box Size: 310 x 248 x 49 mm Carton Size: 550 x 330 x 290 mm Outer Box QTY: 400 pcs per outer box Carton QTY: 4,000 pcs per carton cuidevices.com date 08/05/2022 | page 3 of 4 Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPT-1495C-300 | DESCRIPTION: PIEZO BUZZER TRANSDUCER date 08/05/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 03/30/2016 1.01 brand update 11/22/2019 logo, datasheet style update 08/05/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CPT-1495C-300 价格&库存
很抱歉,暂时无法提供与“CPT-1495C-300”相匹配的价格&库存,您可以联系我们找货
