Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CPT-1495CI-300 | DESCRIPTION: PIEZO BUZZER TRANSDUCER
FEATURES
• externally driven
• wave solderable
• IP67 rated
SPECIFICATIONS
parameter
conditions/description
min
typ
operating voltage
current consumption
at 10 Vp-p, 4,250 Hz square wave
rated frequency
max
units
30
Vp-p
12
mA
4,250
sound pressure level
at 10 cm, 10 Vp-p, 4,250 Hz square wave
electrostatic capacity
at 1,000 Hz/1 V
dimensions
Ø14.0 x 10.0
Hz
84
14,000
dB
20,000
26,000
pF
mm
weight
material
PBT+15% Glass
terminal
pin type (Au plating)
2.60
g
operating temperature
-30
85
°C
storage temperature
-40
95
°C
max
units
380
°C
260
°C
RoHS
yes
IP level
Notes:
IP67 (IEC standard 529 edition 2.0 (1989))
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
for maximum 5 seconds
330
wave soldering
see recommended wave soldering profile
Wave Solder Profile
5 Sec Max
260
2~5 °C/Sec
Temperature (°C)
200 °C/Sec
2~5 °C/Sec
120
25
40 Sec
60 Sec
Preheating
1.5
Sec Max
Melting
Time (sec)
cuidevices.com
100 Sec
Cooling
typ
Product Page
3D Model
CUI DEVICES | MODEL: CPT-1495CI-300 | DESCRIPTION: PIEZO BUZZER TRANSDUCER
PCB Footprint
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
Note 1. Part is designed as a sealed transducer to protect inner structure.
FREQUENCY RESPONSE CURVE
100
90
dB
80
70
60
50
Hz
cuidevices.com
2K
20K
Product Page
3D Model
PACKAGING
units: mm
Carton Size: 230 x 230 x 270 mm
Tray QTY: 100 pcs per tray
Carton QTY: 1,000 pcs per carton
cuidevices.com
PCB Footprint
date 08/05/2022 | page 3 of 4
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
03/30/2016
1.01
brand update
11/22/2019
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPT-1495CI-300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+22.46610100+2.68620
- 200+22.18760200+2.65290
- 300+22.09476300+2.64180
- 400+22.00193400+2.63070
- 500+21.72342500+2.59740
