Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 4
MODEL: CPI-42533C-120 | DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• includes driving circuit
• wire leads
• 12 Vdc rated voltage
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
6
at rated voltage
continuous tone
slow pulse tone
rated frequency
2,300
sound pressure level
at 30 cm, rated voltage
continuous tone
slow pulse tone
tone
continuous (black wire)
slow pulse at rated voltage (blue wire)
dimensions
Ø42.5 x 33.0
2,800
0.96
material
ABS UL94 1/16” HB High Heat
terminal
wire type
Vdc
Vdc
13
11
mA
mA
3,300
Hz
dB
dB
1.2
1.44
Hz
mm
operating temperature
storage temperature
Notes:
units
28
92
87
weight
RoHS
max
12
operating voltage
current consumption
typ
38
g
-30
85
°C
-40
95
°C
max
units
380
°C
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
for maximum 5 seconds
330
cuidevices.com
typ
Product Page
3D Model
CUI DEVICES | MODEL: CPI-42533C-120 | DESCRIPTION: PIEZO BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
wire: UL1007 LF 18 AWG
Voltage vs. Sound Pressure Level
at 30 cm
110
Voltage vs. Current Consumption
Current Consumption (mA)
Sound Pressure Level (dB)
PERFORMANCE CURVES
108
106
104
102
100
98
6
8
37
32
27
22
17
12
10 12 14 16 18 20 22 24 26 28
Voltage (Vdc)
cuidevices.com
7
2
6
8
Voltage (Vdc)
Product Page
PACKAGING
units: mm
Outer Box Size: 310 x 248 x 49 mm
Carton Size: 530 x 330 x 260 mm
Outer Box QTY: 35 pcs per outer box
Carton QTY: 350 pcs per carton
cuidevices.com
3D Model
date 08/05/2022 | page 3 of 4
Product Page
3D Model
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
04/06/2016
1.01
updated packaging
07/01/2016
1.02
updated wire descriptions
01/22/2019
1.03
brand update
12/11/2019
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPI-42533C-120”相匹配的价格&库存,您可以联系我们找货
