CPI-4232C-120
CPI-4232C-120
    CUIDEVICES
    AUDIOPIEZOIND8-18VPNLMNT
CPI-4232C-120 数据手册
Additional Resources: Product Page | 3D Model date 08/05/2022 page 1 of 4 MODEL: CPI-4232C-120 | DESCRIPTION: PIEZO BUZZER INDICATOR FEATURES • includes driving circuit • screw terminal mount • 95 dB SPL SPECIFICATIONS parameter conditions/description min rated voltage 8 at 8 Vdc at 12 Vdc at 18 Vdc rated frequency 2,400 sound pressure level at 60 cm, 8 Vdc at 60 cm, 12 Vdc at 60 cm, 18 Vdc dimensions Ø42.5 x 32.5 2,900 material nylon terminal screw terminals (Sn plating) Vdc Vdc 8 16 24 mA mA mA 3,400 Hz dB dB dB mm operating temperature storage temperature Notes: units 18 80 92 95 weight RoHS max 12 operating voltage current consumption typ 32.0 g -30 85 °C -40 85 °C max units 380 °C yes 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description min hand soldering for maximum 5 seconds 330 cuidevices.com typ Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPI-4232C-120 | DESCRIPTION: PIEZO BUZZER INDICATOR date 08/05/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: ±0.5 mm 110 Voltage vs. Sound Pressure Level at 60 cm Voltage vs. Current Consumption Current Consumption (mA) Sound Pressure Level (dB) PERFORMANCE CURVES 108 106 104 102 100 8 10 12 14 Voltage (Vdc) 16 18 16 14 12 10 18 8 6 4 8 10 12 14 Voltage (Vdc) cuidevices.com 16 18 Additional Resources: Product Page | CUI DEVICES | MODEL: CPI-4232C-120 | DESCRIPTION: PIEZO BUZZER INDICATOR PACKAGING units: mm Outer Box Size: 310 x 248 x 49 mm Carton Size: 550 x 330 x 290 mm Outer Box QTY: 40 pcs per outer box Carton QTY: 400 pcs per carton cuidevices.com 3D Model date 08/05/2022 | page 3 of 4 Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CPI-4232C-120 | DESCRIPTION: PIEZO BUZZER INDICATOR date 08/05/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 03/31/2016 1.01 brand update 11/22/2019 logo, datasheet style update 08/05/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CPI-4232C-120 价格&库存
很抱歉,暂时无法提供与“CPI-4232C-120”相匹配的价格&库存,您可以联系我们找货
