SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
CAPACITANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNIT
5
1 ~ 25
Vp-p
Vp-p
2.9
12,000 30%
mA
pF
73
4,100 500
dBA
Hz
C
C
grams
-40 ~ +80
-40 ~ +80
LCP
Sn PLATED BRASS
0.3
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
RELEASED FROM ENGINEERING
REVISED REEL DESIGN TO USE OPEN SQUARE POCKET WITH
PART TURNED 90 STARTING WITH DATE CODE 17F
6/2/2016
A
2
0.3 (2)
0.3
11
0.3
5/25/17
M.V.
DETAIL "A"
0.1 MAX.
0.1 MAX.
15
APPROVED
9
A
1.7
0.3
2
0.3
0.3
0.2
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
4. 260 C MAX. REFLOW TEMPERATURE, MAX 10sec.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
SMT-1141-T-5-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
J.A.F.
6/2/2016
B.R.
6/2/2016
R.W.
6/2/2016
6/2/2016
SMT-1141-T-5-R
Transducer (Piezo)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMT-1141-T-5-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+11.332422000+1.46001
- 4000+11.024694000+1.42036
- 国内价格 香港价格
- 1+22.915091+2.95225
- 10+17.9753310+2.31584
- 25+16.3626025+2.10807
- 50+15.2542350+1.96527
- 100+14.23339100+1.83375
- 250+13.49422250+1.73852
