SMT-0927-S-8-R
SMT-0927-S-8-R
    PUIAUDIO
    Peak-Peak Signal Buzzer Single Tone 2.7kHz Magnetic 2.5 ~ 4.5V 87dB @ 3.6V, 10cm
SMT-0927-S-8-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNIT 3.6 2.5 ~ 4.5 100 15 3 87 2,700 500 -30 ~ +85 -40 ~ +85 LCP Sn PLATED BRASS 0.8 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 2014/07/30 mA OHM dBA Hz C C grams 4 DUMMY PAD 06.J T0827S2R PUI KOREA 8.5 8.5 DUMMY PAD APPROVED 0.15 1.5 4X 0.05 POLARITY PAD (-) POLARITY PAD (+) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-0927-S-8-R.idw Designed by Date Checked by Date Approved by J.D. 7/30/2014 C.W. 7/30/2014 B.R. Date Drawn Date 7/30/2014 7/30/2014 SMT-0927-S-8-R Transducer (Electro-Mech) Edition Sheet - 1/1
SMT-0927-S-8-R 价格&库存
很抱歉,暂时无法提供与“SMT-0927-S-8-R”相匹配的价格&库存,您可以联系我们找货
SMT-0927-S-8-R
  • 1000+14.893701000+1.93388
  • 2000+13.890992000+1.80368
  • 3000+13.836413000+1.79659
库存:254
SMT-0927-S-8-R
  • 1+33.972231+4.41113
  • 10+25.9170310+3.36520
  • 25+23.3711925+3.03464
  • 50+21.6477350+2.81085
  • 100+20.07903100+2.60717
  • 250+18.21633250+2.36530
  • 500+15.98839500+2.07602
库存:254
