AT-0927-TT-5-R
AT-0927-TT-5-R
    PUIAUDIO
    AUDIO MAGNETIC XDCR 1-2V TH
AT-0927-TT-5-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNIT 1.5 1~2 90 6 1 85 2,730 500 -20 ~ +70 -30 ~ +80 PBT Au PLATED BRASS 1 Vpk Vpk THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PUI AUDIO, INC. IS PROHIBITED. LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING REVISED HOUSING MATERIAL 7/15/2014 2/14/2020 M.L. 2010, PUI AUDIO Inc. mA OHM dBA Hz C C grams 4.5 9 REVISION HISTORY 4.5 0.3 0.3 4 0.6 0.2 0.1 (2) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2015/863/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: All PURCHASES ARE SUBJECT TO AND INCORPORATE THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com /pdf/terms_conditions.pdf (paper copy available upon request). DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-0927-TT-5-R.idw Designed by Date Checked by Date Approved by J.D. 7/15/2014 C.W. 7/15/2014 B.R. Date Drawn Date 7/15/2014 7/15/2014 AT-0927-TT-5-R Transducer (Electro-Mech) Edition Sheet - 1/1
AT-0927-TT-5-R 价格&库存
很抱歉,暂时无法提供与“AT-0927-TT-5-R”相匹配的价格&库存,您可以联系我们找货
AT-0927-TT-5-R
    • 1+3.96360
    • 200+1.53360
    • 500+1.47960
    • 1000+1.45800
