SMT-0927-S-11-R
SMT-0927-S-11-R
    PUIAUDIO
    AUDIOMAGNETICXDCR2.5-4.5VSMD
SMT-0927-S-11-R 数据手册
SPECIFICATIONS VALUES UNIT 3.6 2.5 ~ 4.5 90 16 3 90 2,670 500 -30 ~ +70 -40 ~ +85 LCP Sn plated Brass 0.8 V0-p V0-p PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT +0.4 8.5 0 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING REVISED VOLTAGE FROM Vp-p to V0-p 8/16/16 1/19/21 M.V. mA OHM dBA Hz C C grams DUMMY PAD +0.2 1.3 - 0 0.3 0.8 0.1 0.1 (4) 6/K POLARITY PAD (-) THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. POLARITY PAD (+) SMT 0927 S11R D +0.4 8.5 - 0 +0.4 8.7 0 3 DUMMY PAD 1.2 2.75 0.1 6.6 0.1 3.25 6 0.1 0.1 +0 3 - 0.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMT-0927-S-11-R.idw Designed by Date Checked by Date Approved by J.D. 10/18/2006 R.W. 10/18/2006 R.W. Date Drawn Date 10/18/2006 5/5/2010 SMT-0927-S-11-R Transducer (Electro-Mech) Edition Sheet - 1/1
SMT-0927-S-11-R 价格&库存
很抱歉,暂时无法提供与“SMT-0927-S-11-R”相匹配的价格&库存,您可以联系我们找货
SMT-0927-S-11-R
    • 1+18.37080
    • 200+7.10640
    • 500+6.85800
    • 1000+6.73920
    SMT-0927-S-11-R
    • 1000+22.195821000+2.87989
    • 2000+21.583842000+2.80049
    库存:17995
    SMT-0927-S-11-R
    • 1+47.409901+6.15140
    • 10+36.2228310+4.69989
    • 25+32.7062225+4.24361
    • 50+30.3252850+3.93468
    • 100+28.15291100+3.65282
    • 250+25.56902250+3.31756
    • 500+23.80796500+3.08907
    库存:17995
