SMT-1427-S-R
14x11mm Transducer
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• Side-firing electromechanical transducer designed for 3 to 7 Vp-p
• Small footprint with loud 85 dB output
• 2,700 Hz resonant frequency targets most sensi%ve region of human hearing
• Designed for reflow soldering with a lead-free reflow profile
Frequency Response (3.6 Vp-p @ 0.1 meters)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 9/15.
AT-1438-TWT-R
SMT-1427-S-R
40mm Speaker
14x11m Transducer
Mechanical and Environment Testing
Test Description
Test Condition
High Temperature
85°C (±2°C) with random humidity for 96 hours
Low Temperature
Drop Test
-40°C (±2°C) with random humidity for 96 hours
25°C to 60°C with 90% to 95% relative humidity
for 12 hours, 10 cycles
1.53 mm movement modulated at 10-55 Hz in 3
directions for 6 hours
120 cm free fall in six directions, 3 cycles
Temperature Cycle Test
-30°C to 70°C, five 90 minute cycles
Humidity
Vibration
Tape Dimensions
Recommended Reflow Profile
Recommended Land Pattern
SPECIFICATIONS
PARAMETERS
VALUES
UNITS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
5
3~7
80
30 ± 4.5
85
2,700 ± 500
Vp-p
Vp-p
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
-30 ~ +60
-40 ~ +85
LCP
Sn PLATED
PHOSPHOR BRONZE
0.7
14.2
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
A
DATE
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
5/9/2006
5/10/2010
APPROVED
B.R.
mA
OHM
dBA
Hz
°C
°C
grams
2 X 45°
CHAMFER
(TYP. (2) LOC.)
2.1
3.4
2.5
11
2
SOUND
EMISSION
HOLE
0.5
1.4
2
2.3
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
SMT-1427-S-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
J.D.
5/9/2006
E.P.
5/9/2006
B.R.
5/9/2006
5/10/2010
SMT-1427-S-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMT-1427-S-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+26.432651000+3.43499
- 2000+26.219742000+3.40733
- 国内价格 香港价格
- 1+49.578671+6.44288
- 10+39.0341410+5.07259
- 25+35.5785625+4.62353
- 50+33.2027950+4.31479
- 100+32.09292100+4.17056
