SMI-1324-TW-12V-R-T/R
    PUIAUDIO
    BUZZER MAG 12V 13.1 X 12.5MM SMD
SMI-1324-TW-12V-R-T/R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS Vdc RATED VOLTAGE 12 OPERATING VOLTAGE RANGE 8 ~ 15 Vdc RATED CURRENT (MAX) 30 mA MINIMUM SPL @ 10 CM 85 dBA 2,400 300 RESONANT FREQUENCY Hz 0 pulse/sec TONE OR PULSE RATE CONTINUOUS -20 ~ +70 OPERATING TEMPERATURE C STORAGE TEMPERATURE -30 ~ +85 C PA46 HOUSING MATERIAL TERMINAL MATERIAL Sn PLATED BRASS grams 5 WEIGHT THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E F RELEASED FROM ENGINEERING UPDATED HOUSING MATERIAL ADDED RoHS COMPLIANCE NOTE ADDED NOTE 4 REVISED TERMINAL MATERIAL REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED STORAGE TEMPERATURE 10/13/2004 4/19/2005 8/10/2005 11/2/2005 3/20/2006 5/28/2010 2/27/2020 R.W. B.R. B.R. B.R. M.V. 13.1 12.5 6.5 2.2 SOUND HOLE EMISSION 1.2 TYP. 2.2 12.5 2 REMOVABLE WASH TAB 11.3 EPOXY POTTING 3.7 1.2 TYP. 6.7 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. MAXIMUM REFLOW TEMPERATURE IS 260 C. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMI-1324-TW-12V-R.idw Designed by Date R.A.C. 10/13/2004 Checked by Date Approved by R.W. Date Drawn Date 10/13/2004 5/28/2010 SMI-1324-TW-12V-R Indicator Edition Sheet - 1/1
SMI-1324-TW-12V-R-T/R 价格&库存
很抱歉,暂时无法提供与“SMI-1324-TW-12V-R-T/R”相匹配的价格&库存,您可以联系我们找货
  • 350+37.06613350+4.81684
  • 700+34.56238700+4.49147
  • 1050+33.966431050+4.41403
库存:285
  • 1+62.452921+8.11592
  • 10+49.2259110+6.39704
  • 25+44.8919325+5.83382
  • 50+41.9059150+5.44578
  • 100+41.57500100+5.40278
库存:285
