SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNIT
1.5
1~2
40
16 4
85
2,250 250
-20 ~ +80
-30 ~ +85
NORYL
Sn PLATED COPPER
7
Vpk
Vpk
SOUND
EMISSION HOLE
18
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
RELEASED FROM ENGINEERING
REVISED PART HEIGHT DIMENSION
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED RESONANT FREQUENCY
3/21/2006
5/11/2010
5/12/2010
2/19/2020
B.R.
B.R.
M.L.
2003, Projects Unlimited Inc.
mA
OHM
dBA
Hz
C
C
grams
REMOVABLE
WASH TAB
4.5
+0
10.5 - 0.2
0.2
6.5
0.6
14
0.2
0.05 (2)
EPOXY POTTING
0.2
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2015/863/EU COMPLIANT.
4. WAVE SOLDER AND WASH ALLOWED.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AT-1820-TWT-1V-R.idw
Designed by
Date
Checked by
Date
Approved by
T.G.
3/21/2006
B.R.
3/21/2006
E.P.
Date
Drawn Date
3/21/2006 5/12/2010
AT-1820-TWT-1V-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AT-1820-TWT-1V-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+20.8453850+2.70196
- 国内价格
- 1+40.82400
- 200+16.28640
- 500+15.74640
- 1000+15.47640
