SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
12
8 ~ 16
40
140 14
85
2,400 500
-30 ~ +70
-40 ~ +85
NORYL
Sn PLATED BRASS
5
Vp-p
Vp-p
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED TEMPERATURE SPECIFICATIONS
1/16/2006
6/4/2010
3/2/2020
B.R.
M.V.
mA
OHM
dBA
Hz
C
C
grams
6.5
13.1
2.2
WASH TAB
_
12.5
2
2.2 SOUND
EMISSION HOLE
11.3
12.5
EPOXY
3.7
6.7
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
SMT-1324-TW-12V-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
J.A.F.
1/16/2006
E.P.
1/16/2006
B.R.
1/16/2006
6/4/2010
SMT-1324-TW-12V-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMT-1324-TW-12V-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+14.31000
- 200+5.54040
- 500+5.34600
- 1000+5.24880
