Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CMI-9650C-120 | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• includes driving circuit
• wave solderable
• washable
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
typ
max
12.0
operating voltage
10.0
current consumption
rated frequency
sound pressure level
at 10 cm (A-weight), rated voltage
dimensions
Ø9.6 x 5.0
2,330
2,730
85
90
units
Vdc
13.0
Vdc
30
mA
3,130
Hz
dBA
mm
weight
0.6
material
PBT
terminal
pin type (Sn plating)
g
operating temperature
-20
70
°C
storage temperature
-30
85
°C
max
units
250
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
Wave Solder Profile
3 Sec Max
250
2~5 °C/Sec
Temperature (°C)
130 °C/Sec
2~5 °C/Sec
110
25
40 Sec
60 Sec
Preheating
1.5
Sec Max
Melting
Time (sec)
cuidevices.com
100 Sec
Cooling
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMI-9650C-120 | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
CMI9650C
12V 01
16
ŘņņŌ
ıIJ
ıij
PERFORMANCE CURVES
100
95
90
85
80
75
10
12
13
Voltage (Vdc)
Voltage vs. Current Consumption
at 25°C
Current Consumption (mA)
Sound Pressure Level (dB)
Voltage vs. Sound Pressure Level
at 10 cm, 25°C
35
30
25
10
10
12
13
Voltage (Vdc)
cuidevices.com
Śņłœ
IJķĮĮĮijıIJķ
IJĸĮĮĮijıIJĸ
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Tray Size: 240 x 160 x 28 mm
Carton Size: 510 x 420 x 280 mm
Tray QTY: 100 pcs per tray
Carton QTY: 5,000 pcs per carton
[ 3&6
)RDP7UD\
Lot No.
XXXXXXXXXX
Model No. XXXXXXXXXX
Quantity.
XXXX
Pcs
Date:
DD MM YY
G
MADE IN CHINA
CUI Inc
The label is placed on the inner
boxes and outer carton.
&DUWRQ%R[
3&62XW%R[
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
03/30/2016
1.01
brand update
12/11/2019
1.02
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMI-9650C-120”相匹配的价格&库存,您可以联系我们找货
