AT-3425-TWT-R
AT-3425-TWT-R
    PUIAUDIO
    AUDIO PIEZO TRANSDUCER 3-28V TH
AT-3425-TWT-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 12 3 ~ 28 7 21,000 30% 85 2,500 500 -30 ~ +85 -40 ~ +95 UL94 ABS Au PLATED PHOSPHOR BRONZE 3.7 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED FEEDBACK LOOP REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED WEIGHT 9/12/2005 1/2/2008 10/3/2008 2/27/2020 R.W. B.R. M.V. 2003, Projects Unlimited Inc. mA pF dBA Hz C C grams 14.9 LOCATING DOT GROUND 11.5 8.1 5.6 0.2 SOUND EMISSION HOLE GROUND 3.5 120 0.6 REMOVEABLE WASH TAB MAIN FEEDBACK 33.6 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. PART WASHABLE USING DEIONIZED WATER, OR PURE ISOPROPYL ALCOHOL. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-3425-TWT-R.idw Designed by Date Checked by Date Approved by J.A.F. 9/12/2005 B.R. 9/12/2005 E.P. Date Drawn Date 9/12/2005 10/3/2008 AT-3425-TWT-R Transducer (Piezo) Edition Sheet - 1/1
AT-3425-TWT-R 价格&库存
很抱歉,暂时无法提供与“AT-3425-TWT-R”相匹配的价格&库存,您可以联系我们找货
