SMI-1324-TW-5V-3-R
SMI-1324-TW-5V-3-R
    PUIAUDIO
    BUZZER MAGNETIC 5V 12.8MM SMD
SMI-1324-TW-5V-3-R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS 5 Vdc RATED VOLTAGE OPERATING VOLTAGE RANGE 3~8 Vdc RATED CURRENT (MAX) 30 mA MINIMUM SPL @ 10 CM 88 dBA 2,400 500 RESONANT FREQUENCY Hz 0 pulse/sec TONE OR PULSE RATE CONTINUOUS -25 ~ +70 OPERATING TEMPERATURE C STORAGE TEMPERATURE -30 ~ +80 C HOUSING MATERIAL PPS TERMINAL MATERIAL Au PLATED BRASS grams WEIGHT 2 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED OPERATING VOLTAGE RANGE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED PART HEIGHT DIMENSIONS REVISED LENGTH AND WIDTH REVISED VOLTAGE RANGE AND TEMPERATURE SPECIFICATIONS 7/17/2008 11/3/2009 5/28/2010 7/28/2010 10/29/2012 B.R. B.R. B.R. B.R. 2/28/2020 M.V. E D6F DATE CODE MARKING "6 F" SILK SCREEN MARKING POSITIVE TERMINAL MONTH:F=JUN YEAR:6=2006 7.4 0.1 0.5 6.9 2 SOUND EMISSION HOLE 2 0.1 12.8 9.8 1.6 (3) 12.8 3.5 3.5 0.2 0.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMI-1324-TW-5V-3-R.idw Designed by Date Checked by Date Approved by J.D. 11/1/2008 B.R. 11/1/2008 C.W. Date Drawn Date 11/1/2008 5/28/2010 SMI-1324-TW-5V-3-R Indicator Edition Sheet - 1/1
SMI-1324-TW-5V-3-R 价格&库存
很抱歉,暂时无法提供与“SMI-1324-TW-5V-3-R”相匹配的价格&库存,您可以联系我们找货
SMI-1324-TW-5V-3-R
    • 1+28.92240
    • 300+11.19960
    • 600+10.80000
    • 900+10.60560
    SMI-1324-TW-5V-3-R
    • 300+37.67466300+4.88826
    • 600+35.12020600+4.55682
    • 900+33.98560900+4.40961
    库存:5521
    SMI-1324-TW-5V-3-R
    • 1+62.488081+8.10778
    • 10+49.2536210+6.39062
    • 25+44.9172025+5.82797
    • 50+41.9295050+5.44032
    • 100+41.59840100+5.39736
    库存:5521
