AW-10PW-NSVC
AW-10PW-NSVC
    PUIAUDIO
    SIREN PIEZO IND 9-28V PNL MNT
AW-10PW-NSVC 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS RATED VOLTAGE 12 Vdc 9 ~ 28 15 IP65 Vdc 106 2,700 ~ 3,100 dBA 4 RED (+) & BLUE (-)/ RED (+) & BLACK (-) Hz -40 ~ +80 ABS/WHITE LEAD WIRE 80 C grams OPERATING VOLTAGE RANGE RATED CURRENT (MAX) INGRESS PROTECTION TYPICAL SPL @ 10 cm FREQUENCY RANGE SWEEP RATE CONTINUOUS TONE/ PULSING TONE OPERATING TEMPERATURE CASE MATERIAL/COLOR TERMINAL WEIGHT THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING ADDED RoHS NOTE REVISED PANEL MOUNT & HEIGHT DIMENSIONS REVISED TO INVENTOR 3-D DRAWING TEMPLATE 12/15/2005 5/21/2007 6/11/2010 6/11/2010 R.W. B.R. B.R. mA Hz - 13.5 31.5 50 203 BLUE (-) AWG #24 STRANDED TINNED COPPER WIRES RED (+) 31 JAMB NUT BLACK (-) 26 JAMB NUT REMOVED POTTING 10 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AW-10PW-NSVC.idw Designed by Date Checked by Date Approved by J.A.F. 12/15/2005 E.P. 12/15/2005 B.R. Date Drawn Date 12/15/2005 6/11/2010 AW-10PW-NSVC Siren Edition Sheet - 1/1
AW-10PW-NSVC 价格&库存
很抱歉,暂时无法提供与“AW-10PW-NSVC”相匹配的价格&库存,您可以联系我们找货
AW-10PW-NSVC
    • 1+209.22840
    • 200+80.96760
    • 500+78.12720
    • 1000+76.72320
