AT-1220-TT-5-R
AT-1220-TT-5-R
    PUIAUDIO
    AUDIO MAGNETIC XDCR 1-3V TH
AT-1220-TT-5-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE (SQUARE WAVE) OPERATING VOLTAGE RANGE RATED CURRENT (MAX) COIL RESISTANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 1.5 1~3 10 50 7.5 73 2,048 100 -30 ~ +70 -40 ~ +85 NORYL Sn PLATED COPPER 2 Vpk Vpk THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PUI AUDIO, INC. IS PROHIBITED. LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED TEMPERATURE RATINGS 7/5/2005 10/15/2007 2/25/2020 B.R. M.L. 2010, PUI AUDIO Inc. mA OHM dBA Hz C C grams 5.5 8 SOUND EMISSION HOLE REVISION HISTORY 12 0.2 5 0.2 _ 6.5 + 0.2 0.6 (2) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2015/863/EU COMPLIANT. 0.5 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-1220-TT-5-R.idw Designed by Date R.C. 7/5/2005 Checked by Date Approved by E.P. Date Drawn Date 7/6/2005 10/15/2007 AT-1220-TT-5-R Transducer (Electro-Mech) Edition Sheet - 1/1
AT-1220-TT-5-R 价格&库存
很抱歉,暂时无法提供与“AT-1220-TT-5-R”相匹配的价格&库存,您可以联系我们找货
AT-1220-TT-5-R
    • 1+10.64880
    • 200+4.25520
    • 500+4.11480
    • 1000+4.03920
    AT-1220-TT-5-R
    • 1+11.953101+1.52240
    • 10+9.1310010+1.16300
    • 25+8.1748025+1.04120
    • 50+7.5684050+0.96390
    • 100+7.00860100+0.89260
    • 300+6.56550300+0.83620
    • 500+5.88910500+0.75010
    • 1000+5.457601000+0.69510
    • 5000+5.247705000+0.66840
    库存:308
