AT-1436-TWT-R
AT-1436-TWT-R
    PUIAUDIO
    AUDIO PIEZO TRANSDUCER 1-20V TH
AT-1436-TWT-R 数据手册
SPECIFICATIONS PARAMETERS RATED VOLTAGE OPERATING VOLTAGE RANGE RATED CURRENT (MAX) CAPACITANCE MINIMUM SPL @ 10 CM RESONANT FREQUENCY OPERATING TEMPERATURE STORAGE TEMPERATURE HOUSING MATERIAL TERMINAL MATERIAL WEIGHT VALUES UNITS 5 1 ~ 20 3 13,000 30% 80 3,600 500 -20 ~ +70 -30 ~ +80 NORYL Sn PLATED RED COPPER 1 Vp-p Vp-p THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED CAPACITANCE 11/7/2005 4/16/2008 3/25/2019 B.R. M.V. 2003, Projects Unlimited Inc. mA pF dBA Hz C C grams 4.5 6.8 13.8 7.6 2 SOUND EMISSION HOLE NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AT-1436-TWT-R.idw Designed by Date Checked by Date Approved by J.A.F. 11/7/2005 B.R. 11/7/2005 E.P. Date Drawn Date 11/7/2005 4/16/2008 AT-1436-TWT-R Transducer (Piezo) Edition Sheet - 1/1
AT-1436-TWT-R 价格&库存
很抱歉,暂时无法提供与“AT-1436-TWT-R”相匹配的价格&库存,您可以联系我们找货
