74AUP2G125GD,125
74AUP2G125GD,125
    NEXPERIA(安世)
    XSON8
    IC BUFFER NON-INVERT 3.6V 8XSON
74AUP2G125GD,125 数据手册
74AUP2G125 Low-power dual buffer/line driver; 3-state Rev. 14 — 21 June 2022 Product data sheet 1. General description The 74AUP2G125 is a dual buffer/line driver with 3-state outputs controlled by the output enable inputs (nOE). Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • • • Wide supply voltage range from 0.8 V to 3.6 V High noise immunity CMOS low power dissipation Low static power consumption; ICC = 0.9 μA (maximum) Latch-up performance exceeds 100 mA per JESD78B Class II Overvoltage tolerant inputs to 3.6 V Low noise overshoot and undershoot < 10 % of VCC Input-disable feature allows floating input conditions IOFF circuitry provides partial Power-down mode operation Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8-12 (0.8 V to 1.3 V) • JESD8-11 (0.9 V to 1.65 V) • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-B (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F Class 3A exceeds 5000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP2G125DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74AUP2G125GT -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 × 1.95 × 0.5 mm SOT833-1 74AUP2G125GF -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1 × 0.5 mm SOT1089 74AUP2G125GN -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2 × 1.0 × 0.35 mm SOT1116 74AUP2G125GS -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1.0 × 0.35 mm SOT1203 74AUP2G125GX -40 °C to +125 °C X2SON8 plastic thermal enhanced extremely thin small outline package; no leads; 8 terminals; body 1.35 × 0.8 × 0.32 mm SOT1233-2 4. Marking Table 2. Marking codes Type number Marking code[1] 74AUP2G125DC p25 74AUP2G125GT p25 74AUP2G125GF aM 74AUP2G125GN aM 74AUP2G125GS aM 74AUP2G125GX aM [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 1A 1Y 1OE EN1 2A 2Y EN2 001aah931 Logic symbol 74AUP2G125 Product data sheet nY nA 2OE Fig. 1. 1 2 001aah932 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 nOE Fig. 3. mna227 Logic diagram (one gate) © Nexperia B.V. 2022. All rights reserved 2 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 6. Pinning information 6.1. Pinning 74AUP2G125 1OE 1 8 VCC 1A 2 7 2OE 2Y 3 6 1Y GND 4 5 2A 74AUP2G125 1OE 1 8 VCC 1A 2 7 2OE 2Y 3 6 1Y GND 4 5 2A 001aae974 Transparent top view 001aae973 Fig. 4. Fig. 5. Pin configuration SOT765-1 (VSSOP8) Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 (XSON8) 74AUP2G125 1OE 1 7 2OE 6 1Y 5 2A 8 VCC 1A 2 4 GND 2Y 3 aaa-023985 Transparent top view Fig. 6. Pin configuration SOT1233-2 (X2SON8) 6.2. Pin description Table 3. Pin description Symbol Pin Description 1OE, 2OE 1, 7 output enable input (active LOW) 1A, 2A 2, 5 data input GND 4 ground (0 V) 1Y, 2Y 6, 3 data output VCC 8 supply voltage 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 3 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Output Input nOE nA nY L L L L H H H X Z 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Active mode and Power-down mode IIK input clamping current IOK Min Max Unit -0.5 +4.6 V [1] -0.5 +4.6 V [1] -0.5 +4.6 V VI < 0 V -50 - mA output clamping current VO < 0 V -50 - mA IO output current VO = 0 V to VCC - ±20 mA ICC supply current - +50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation [1] [2] [3] [4] [5] [6] [7] Tamb = -40 °C to +125 °C SOT765-1 (VSSOP8) SOT833-1 (XSON8) SOT1089 (XSON8) SOT1116 (XSON8) SOT1203 (XSON8) [2] [3] [4] [5] [6] - 250 250 250 250 250 mW mW mW mW mW SOT1233-2 (X2SON8) [7] - 300 mW The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT765-1 (VSSOP8) package: Ptot derates linearly with 4.9 mW/K above 99 °C. For SOT833-1 (XSON8) package: Ptot derates linearly with 3.1 mW/K above 68 °C. For SOT1089 (XSON8) package: Ptot derates linearly with 4.0 mW/K above 88 °C. For SOT1116 (XSON8) package: Ptot derates linearly with 4.2 mW/K above 90 °C. For SOT1203 (XSON8) package: Ptot derates linearly with 3.6 mW/K above 81 °C. For SOT1233-2 (X2SON8) package: Ptot derates linearly with 7.7 mW/K above 118 °C. 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 4 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 9. Recommended operating conditions Table 6. Operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate Active mode Power-down mode; VCC = 0 V VCC = 0.8 V to 3.6 V Min Max Unit 0.8 3.6 V 0 3.6 V 0 VCC V 0 3.6 V -40 +125 °C - 200 ns/V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 0.8 V 0.70 × VCC - - V VCC = 0.9 V to 1.95 V 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30 × VCC V VCC = 0.9 V to 1.95 V - - 0.35 × VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.75 × VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.11 - - V IO = -1.9 mA; VCC = 1.65 V 1.32 - - V IO = -2.3 mA; VCC = 2.3 V 2.05 - - V IO = -3.1 mA; VCC = 2.3 V 1.9 - - V IO = -2.7 mA; VCC = 3.0 V 2.72 - - V IO = -4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3 × VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V Tamb = 25 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL IO = -20 μA; VCC = 0.8 V to 3.6 V VOL LOW-level output voltage 74AUP2G125 Product data sheet VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 5 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Symbol Parameter Conditions Min Typ Max Unit II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - ±0.1 μA IOZ OFF-state output current VI = VIH or VIL; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - ±0.1 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - ±0.2 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - ±0.2 μA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 μA ΔICC additional supply current data input; VI = VCC - 0.6 V; IO = 0 A; [1] VCC = 3.3 V - - 40 μA nOE input; VI = VCC - 0.6 V; IO = 0 A; [1] VCC = 3.3 V - - 110 μA all inputs; VI = GND to 3.6 V; nOE = GND; VCC = 0.8 V to 3.6 V - - 1 μA [2] CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.8 - pF CO output capacitance output enabled; VO = GND; VCC = 0 V - 1.4 - pF output disabled; VO = GND or VCC = 0 V; VCC = 0 V to 3.6 V - 1.3 - pF 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 6 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Symbol Parameter Conditions Min Typ Max Unit VCC = 0.8 V 0.70 × VCC - - V VCC = 0.9 V to 1.95 V 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30 × VCC V VCC = 0.9 V to 1.95 V - - 0.35 × VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = -20 μA; VCC = 0.8 V to 3.6 V VCC - 0.1 - - V IO = -1.1 mA; VCC = 1.1 V 0.7 × VCC - - V IO = -1.7 mA; VCC = 1.4 V 1.03 - - V IO = -1.9 mA; VCC = 1.65 V 1.30 - - V IO = -2.3 mA; VCC = 2.3 V 1.97 - - V IO = -3.1 mA; VCC = 2.3 V 1.85 - - V IO = -2.7 mA; VCC = 3.0 V 2.67 - - V IO = -4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3 × VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V Tamb = -40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - ±0.5 μA IOZ OFF-state output current VI = VIH or VIL; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - ±0.5 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - ±0.5 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - ±0.6 μA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 μA ΔICC additional supply current data input; VI = VCC - 0.6 V; IO = 0 A; [1] VCC = 3.3 V - - 50 μA nOE input; VI = VCC - 0.6 V; IO = 0 A; [1] VCC = 3.3 V - - 120 μA all inputs; VI = GND to 3.6 V; nOE = GND; VCC = 0.8 V to 3.6 V - - 1 μA 74AUP2G125 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 7 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Symbol Parameter Conditions Min Typ Max Unit VCC = 0.8 V 0.75 × VCC - - V VCC = 0.9 V to 1.95 V 0.70 × VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.25 × VCC V VCC = 0.9 V to 1.95 V - - 0.30 × VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = -20 μA; VCC = 0.8 V to 3.6 V VCC - 0.11 - - V IO = -1.1 mA; VCC = 1.1 V 0.6 × VCC - - V IO = -1.7 mA; VCC = 1.4 V 0.93 - - V IO = -1.9 mA; VCC = 1.65 V 1.17 - - V IO = -2.3 mA; VCC = 2.3 V 1.77 - - V IO = -3.1 mA; VCC = 2.3 V 1.67 - - V IO = -2.7 mA; VCC = 3.0 V 2.40 - - V IO = -4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 μA; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33 × VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VIL LOW-level input voltage VOH VOL HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - ±0.75 μA IOZ OFF-state output current VI = VIH or VIL; VO = 0 V to 3.6 V; VCC = 0 V to 3.6 V - - ±0.75 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - ±0.75 μA ΔIOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - ±0.75 μA ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 μA ΔICC additional supply current data input; VI = VCC - 0.6 V; IO = 0 A; [1] VCC = 3.3 V - - 75 μA nOE input; VI = VCC - 0.6 V; IO = 0 A; [1] VCC = 3.3 V - - 180 μA all inputs; VI = GND to 3.6 V; nOE = GND; VCC = 0.8 V to 3.6 V - - 1 μA [1] [2] [2] One input at VCC - 0.6 V, other input at VCC or GND. To show ICC remains very low when the input-disable feature is enabled. 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 8 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9. Symbol Parameter Conditions 25 °C Tamb = Tamb = Unit -40 °C to +85 °C -40 °C to +125 °C Min Typ[1] Max Min Max Min Max - 20.6 - - - - - ns VCC = 1.1 V to 1.3 V 2.8 5.5 10.5 2.5 11.7 2.5 12.9 ns VCC = 1.4 V to 1.6 V 2.2 3.9 6.1 2.0 7.3 2.0 8.1 ns VCC = 1.65 V to 1.95 V 1.9 3.2 4.8 1.7 6.1 1.7 6.7 ns VCC = 2.3 V to 2.7 V 1.6 2.6 3.6 1.4 4.3 1.4 4.9 ns VCC = 3.0 V to 3.6 V 1.4 2.4 3.1 1.2 3.9 1.2 4.4 ns - 69.9 - - - - - ns VCC = 1.1 V to 1.3 V 3.1 6.1 11.8 2.9 13.9 2.9 15.4 ns VCC = 1.4 V to 1.6 V 2.5 4.2 6.6 2.3 7.7 2.3 8.3 ns VCC = 1.65 V to 1.95 V 2.1 3.4 5.1 2.0 6.2 2.0 6.8 ns VCC = 2.3 V to 2.7 V 1.8 2.6 3.7 1.7 4.5 1.7 5.0 ns VCC = 3.0 V to 3.6 V 1.7 2.4 3.1 1.7 3.5 1.7 3.9 ns - 14.3 - - - - - ns VCC = 1.1 V to 1.3 V 2.7 4.3 6.5 2.7 7.3 2.7 8.2 ns VCC = 1.4 V to 1.6 V 2.1 3.2 4.4 2.1 5.1 2.1 5.7 ns VCC = 1.65 V to 1.95 V 2.0 3.0 4.3 2.0 5.0 2.0 5.7 ns VCC = 2.3 V to 2.7 V 1.4 2.2 2.9 1.4 3.3 1.4 4.1 ns VCC = 3.0 V to 3.6 V 1.7 2.5 3.2 1.7 3.4 1.7 3.9 ns CL = 5 pF tpd ten propagation nA to nY; see Fig. 7. delay VCC = 0.8 V enable time nOE to nY; see Fig. 8. [2] [3] VCC = 0.8 V tdis disable time nOE to nY; see Fig. 8. VCC = 0.8 V 74AUP2G125 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 9 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Symbol Parameter Conditions 25 °C Tamb = Tamb = Unit -40 °C to +85 °C -40 °C to +125 °C Min Typ[1] Max Min Max Min Max - 24.0 - - - - - ns VCC = 1.1 V to 1.3 V 3.2 6.4 12.3 3.0 13.8 3.0 15.2 ns VCC = 1.4 V to 1.6 V 2.1 4.5 7.3 1.9 8.5 1.9 9.4 ns VCC = 1.65 V to 1.95 V 1.9 3.8 5.5 1.7 6.8 1.7 7.6 ns VCC = 2.3 V to 2.7 V 2.1 3.2 4.2 1.6 5.3 1.6 5.9 ns VCC = 3.0 V to 3.6 V 1.8 3.0 3.8 1.6 4.6 1.6 5.2 ns - 73.7 - - - - - ns VCC = 1.1 V to 1.3 V 3.6 6.9 13.5 3.4 15.8 3.4 17.5 ns VCC = 1.4 V to 1.6 V 2.3 4.8 7.7 2.2 8.6 2.2 9.4 ns VCC = 1.65 V to 1.95 V 2.0 3.9 5.8 1.9 6.8 1.9 7.4 ns VCC = 2.3 V to 2.7 V 1.8 3.2 4.3 1.7 5.3 1.7 5.9 ns VCC = 3.0 V to 3.6 V 1.7 3.0 3.9 1.7 4.3 1.7 4.8 ns - 32.7 - - - - - ns VCC = 1.1 V to 1.3 V 3.4 5.4 7.9 3.4 8.8 3.4 9.9 ns VCC = 1.4 V to 1.6 V 2.2 4.1 5.5 2.2 6.2 2.2 7.1 ns VCC = 1.65 V to 1.95 V 2.2 4.2 5.6 1.9 6.3 1.9 7.1 ns VCC = 2.3 V to 2.7 V 1.7 3.0 3.8 1.7 4.5 1.7 5.1 ns VCC = 3.0 V to 3.6 V 2.1 3.8 4.8 1.7 5.0 1.7 5.6 ns CL = 10 pF tpd ten propagation nA to nY; see Fig. 7. delay VCC = 0.8 V enable time nOE to nY; see Fig. 8. [2] [3] VCC = 0.8 V tdis disable time nOE to nY; see Fig. 8. VCC = 0.8 V 74AUP2G125 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 10 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Symbol Parameter Conditions 25 °C Tamb = Tamb = Unit -40 °C to +85 °C -40 °C to +125 °C Min Typ[1] Max Min Max Min Max - 27.4 - - - - - ns VCC = 1.1 V to 1.3 V 3.6 7.2 14.1 3.3 15.8 3.3 17.5 ns VCC = 1.4 V to 1.6 V 3.0 5.1 8.1 2.5 9.8 2.5 10.9 ns VCC = 1.65 V to 1.95 V 2.2 4.3 6.3 2.0 7.9 2.0 8.8 ns VCC = 2.3 V to 2.7 V 2.0 3.7 4.9 1.8 6.0 1.8 6.7 ns VCC = 3.0 V to 3.6 V 2.0 3.5 4.4 1.8 5.4 1.8 6.1 ns - 77.5 - - - - - ns VCC = 1.1 V to 1.3 V 4.0 7.7 15.2 3.7 17.6 3.7 19.6 ns VCC = 1.4 V to 1.6 V 3.0 5.3 8.4 2.5 9.8 2.5 10.7 ns VCC = 1.65 V to 1.95 V 2.3 4.4 6.5 2.1 7.7 2.1 8.5 ns VCC = 2.3 V to 2.7 V 2.1 3.6 5.0 2.0 6.1 2.0 6.8 ns VCC = 3.0 V to 3.6 V 2.0 3.5 4.4 1.9 4.9 1.9 5.5 ns - 60.8 - - - - - ns VCC = 1.1 V to 1.3 V 4.3 6.5 9.2 3.7 10.3 3.7 11.6 ns VCC = 1.4 V to 1.6 V 3.0 5.0 6.5 2.5 7.4 2.5 8.4 ns VCC = 1.65 V to 1.95 V 3.0 5.3 7.0 2.1 7.4 2.1 8.9 ns VCC = 2.3 V to 2.7 V 2.1 3.8 4.9 2.0 5.1 2.0 6.4 ns VCC = 3.0 V to 3.6 V 2.9 5.0 6.2 1.9 6.6 1.9 7.4 ns CL = 15 pF tpd ten propagation nA to nY; see Fig. 7. delay VCC = 0.8 V enable time nOE to nY; see Fig. 8. [2] [3] VCC = 0.8 V tdis disable time nOE to nY; see Fig. 8. VCC = 0.8 V 74AUP2G125 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 11 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Symbol Parameter Conditions 25 °C Tamb = Tamb = Unit -40 °C to +85 °C -40 °C to +125 °C Min Typ[1] Max Min Max Min Max - 37.4 - - - - - ns VCC = 1.1 V to 1.3 V 4.8 9.5 19.0 4.4 21.6 4.4 24.0 ns VCC = 1.4 V to 1.6 V 4.0 6.7 10.8 3.0 13.0 3.0 14.5 ns VCC = 1.65 V to 1.95 V 2.9 5.6 8.4 2.6 10.3 2.6 11.5 ns VCC = 2.3 V to 2.7 V 2.7 4.8 6.3 2.5 7.8 2.5 8.7 ns VCC = 3.0 V to 3.6 V 2.7 4.6 5.8 2.5 7.5 2.5 8.3 ns - 88.9 - - - - - ns VCC = 1.1 V to 1.3 V 5.2 9.9 19.8 4.8 22.8 4.8 25.3 ns VCC = 1.4 V to 1.6 V 4.0 6.8 10.8 3.1 12.6 3.1 14.1 ns VCC = 1.65 V to 1.95 V 3.0 5.6 8.5 2.8 10.2 2.8 11.3 ns VCC = 2.3 V to 2.7 V 2.7 4.8 6.5 2.6 7.8 2.6 8.8 ns VCC = 3.0 V to 3.6 V 2.7 4.6 6.0 2.6 6.9 2.6 7.7 ns - 49.9 - - - - - ns VCC = 1.1 V to 1.3 V 6.0 9.9 13.3 4.8 14.8 4.8 16.5 ns VCC = 1.4 V to 1.6 V 4.4 7.7 9.6 3.1 10.8 3.1 12.1 ns VCC = 1.65 V to 1.95 V 5.1 8.7 11.1 2.8 12.4 2.8 13.8 ns VCC = 2.3 V to 2.7 V 3.6 6.2 7.6 2.6 8.6 2.6 9.6 ns VCC = 3.0 V to 3.6 V 5.2 8.7 10.5 2.6 10.8 2.6 13.1 ns - 2.7 - - - - - pF VCC = 1.1 V to 1.3 V - 2.8 - - - - - pF VCC = 1.4 V to 1.6 V - 2.9 - - - - - pF VCC = 1.65 V to 1.95 V - 3.0 - - - - - pF VCC = 2.3 V to 2.7 V - 3.6 - - - - - pF VCC = 3.0 V to 3.6 V - 4.2 - - - - - pF CL = 30 pF propagation nA to nY; see Fig. 7. delay VCC = 0.8 V tpd enable time nOE to nY; see Fig. 8. ten [2] [3] VCC = 0.8 V disable time nOE to nY; see Fig. 8. tdis [4] VCC = 0.8 V CL = 5 pF, 10 pF, 15 pF and 30 pF output enabled; fi = 1 MHz; [5] power dissipation VI = GND to VCC capacitance VCC = 0.8 V CPD [1] [2] [3] [4] [5] All typical values are measured at nominal VCC. tpd is the same as tPLH and tPHL. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 12 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 11.1. Waveforms and test circuit VI VM nA input GND tPHL tPLH VOH VM nY output VOL mna230 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. The data input (nA) to output (nY) propagation delays Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM 0.8 V to 3.6 V 0.5 × VCC VCC ≤ 3.0 ns 0.5 × VCC VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs enabled outputs disabled mna362 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. Enable and disable times Table 10. Measurement points Supply voltage Input Output VCC VM VM VX VY 0.8 V to 1.6 V 0.5 × VCC 0.5 × VCC VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5 × VCC 0.5 × VCC VOL + 0.3 V VOH - 0.3 V 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 13 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state VCC G VI DUT VEXT 5 kΩ VO RT CL RL 001aac521 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance; CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to the output impedance ZO of the pulse generator; VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 11. Test data Supply voltage Load VCC CL RL [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ open GND 2 × VCC [1] VEXT For measuring enable and disable times RL = 5 kΩ. For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ. 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 14 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 12. Package outline VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 10. Package outline SOT765-1 (VSSOP8) 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 15 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Fig. 11. Package outline SOT833-1 (XSON8) 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 16 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 E terminal 1 index area D A A1 detail X (4×)(2) e L (8×)(2) b 4 5 e1 1 terminal 1 index area 8 L1 X 0 0.5 scale Dimensions Unit mm max nom min 1 mm A(1) 0.5 A1 b D E e e1 L L1 0.04 0.20 1.40 1.05 0.35 0.40 0.15 1.35 1.00 0.55 0.35 0.30 0.35 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version SOT1089 sot1089_po References IEC JEDEC JEITA European projection Issue date 10-04-09 10-04-12 MO-252 Fig. 12. Package outline SOT1089 (XSON8) 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 17 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm 1 2 SOT1116 b 4 3 (4×)(2) L L1 e 8 7 e1 6 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 1.25 1.05 nom 0.15 1.20 1.00 0.55 min 0.12 1.15 0.95 e1 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1116_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1116 Fig. 13. Package outline SOT1116 (XSON8) 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 18 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 b 1 2 3 (4×)(2) 4 L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.40 1.05 0.35 0.40 nom 0.15 1.35 1.00 0.55 0.35 0.30 0.35 min 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1203_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1203 Fig. 14. Package outline SOT1203 (XSON8) 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 19 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state X2SON8: plastic thermal enhanced extremely thin small outline package; no leads; 8 terminals; body 1.35 x 0.8 x 0.32 mm SOT1233-2 C Seating Plane X y C A B D E A A3 2x pin 1 index area 2x e A1 detail X u C e 1 pin 1 index area u C b (6x) 2 8 v w 3 y1 C C A B C 4 Dh L (6x) 7 6 5 b1 (6x) e1 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A max 0.35 nom 0.32 min 0.30 A1 A3 b b1 D Dh E e e1 L u v w y y1 0.04 0.25 0.27 0.27 0.10 0.11 0.02 0.20 1.35 0.22 0.80 0.50 0.54 0.22 0.05 0.10 0.05 0.05 0.05 (Typ.) (ref) 0.00 0.15 0.17 0.17 sot1233-2_po Outline version SOT1233-2 References IEC JEDEC JEITA European projection Issue date 19-11-12 --- Fig. 15. Package outline SOT1233-2 (X2SON8) 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 20 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 13. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP2G125 v.14 20220621 Product data sheet - 74AUP2G125 v.13 Modifications: • 74AUP2G125 v.13 20220310 Modifications: • • • 74AUP2G125 v.12 20170703 Modifications: • • • • Package SOT1233 (X2SON8) changed to SOT1233-2 (X2SON8). Product data sheet - 74AUP2G125 v.12 Type number 74AUP2G125GM (SOT902-2/XQFN8) removed. Section 1 and Section 2 updated. Table 5: Derating values for Ptot total power dissipation have been updated. Product data sheet - 74AUP2G125 v.11 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Fig. 6 and Fig. 15 (drawings SOT1233/X2SON8) updated Type number 74AUP2G125GD removed. 74AUP2G125 v.11 20161028 Modifications: • 74AUP2G125 v.10 20130208 Modifications: • 74AUP2G125 v.9 20120607 Product data sheet - 74AUP2G125 v.8 74AUP2G125 v.8 20111202 Product data sheet - 74AUP2G125 v.7 74AUP2G125 v.7 20100921 Product data sheet - 74AUP2G125 v.6 74AUP2G125 v.6 20091127 Product data sheet - 74AUP2G125 v.5 74AUP2G125 v.5 20090202 Product data sheet - 74AUP2G125 v.4 74AUP2G125 v.4 20090122 Product data sheet - 74AUP2G125 v.3 74AUP2G125 v.3 20080409 Product data sheet - 74AUP2G125 v.2 74AUP2G125 v.2 20070419 Product data sheet - 74AUP2G125 v.1 74AUP2G125 v.1 20061017 Product data sheet - - 74AUP2G125 Product data sheet Product data sheet - 74AUP2G125 v.10 Added type number 74AUP2G125GX (SOT1233/X2SON8) Product data sheet - 74AUP2G125 v.9 For type number 74AUP2G125GD XSON8U has changed to XSON8. All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 21 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AUP2G125 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 22 / 23 74AUP2G125 Nexperia Low-power dual buffer/line driver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................9 11.1. Waveforms and test circuit.......................................13 12. Package outline........................................................ 15 13. Abbreviations............................................................ 21 14. Revision history........................................................21 15. Legal information......................................................22 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 June 2022 74AUP2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 14 — 21 June 2022 © Nexperia B.V. 2022. All rights reserved 23 / 23
74AUP2G125GD,125 价格&库存
很抱歉,暂时无法提供与“74AUP2G125GD,125”相匹配的价格&库存,您可以联系我们找货
