74AHC2G125GD,125
74AHC2G125GD,125
    NEXPERIA(安世)
    XSON8
    IC BUFFER NON-INVERT 5.5V 8XSON
74AHC2G125GD,125 数据手册
74AHC2G125; 74AHCT2G125 Dual buffer/line driver; 3-state Rev. 4 — 2 January 2019 Product data sheet 1. General description The 74AHC2G125 and 74AHCT2G125 are high-speed Si-gate CMOS devices. They provide a dual non-inverting buffer/line driver with 3-state output. The 3-state output is controlled by the output enable input (nOE). A HIGH at nOE causes the output to assume a high-impedance OFF-state. The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V. The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V. 2. Features and benefits • • • • • • • Symmetrical output impedance High noise immunity Low power dissipation Balanced propagation delays Multiple package options ESD protection: • HBM JESD22-A114E: exceeds 2000 V • MM JESD22-A115-A: exceeds 200 V • CDM JESD22-C101C: exceeds 1000 V Specified from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74AHC2G125DP Temperature range Name Description Version -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74AHCT2G125DP 74AHC2G125DC 74AHCT2G125DC 4. Marking Table 2. Marking codes Type number Marking[1] 74AHC2G125DP A25 74AHCT2G125DP C25 74AHC2G125DC A25 74AHCT2G125DC C25 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 5. Functional diagram 2 1A 1 1OE 5 2A 7 1Y 6 2 1 2Y 3 EN1 2OE 6 7 EN2 2 3 nOE mce186 Logic symbol Fig. 2. nY nA 5 mce185 Fig. 1. 1 IEC logic symbol Fig. 3. mna227 Logic diagram (one buffer) 6. Pinning information 6.1. Pinning 74AHC2G125 74AHCT2G125 1OE 1 8 VCC 1A 2 7 2OE 2Y 3 6 1Y GND 4 5 2A 001aaj260 Fig. 4. Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 6.2. Pin description Table 3. Pin description Symbol Pin Description 1OE, 2OE 1, 7 output enable input (active LOW) 1A, 2A 2, 5 data input GND 4 ground (0 V) 1Y, 2Y 6, 3 data output VCC 8 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input Output nOE nA nY L L L L H H H X Z 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage -0.5 +7.0 V VI input voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V [1] -20 - mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 75 mA IGND ground current -75 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC2G125 74AHCT2G125 Unit Min Typ Max Min Typ Max 2.0 5.0 5.5 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature °C Δt/ΔV input transition rise and fall rate -40 +25 +125 -40 +25 +125 VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V -40 °C to +125 °C Unit 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V 74AHC2G125 VIH VIL HIGH-level input voltage LOW-level input voltage 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state Symbol Parameter VOH VOL HIGH-level output voltage LOW-level output voltage Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = -50 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -50 μA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.70 - V IO = 50 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V VI = VIH or VIL VI = VIH or VIL IOZ OFF-state output current VI = VCC or GND; VCC = 5.5 V - - 0.25 - 2.5 - 10 μA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 μA CI input capacitance - 1.5 10 - 10 - 10 pF 74AHCT2G125 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -50 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -8.0 mA 3.94 - - 3.8 - 3.70 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 50 μA - 0 0.1 - 0.1 - 0.1 V IO = 8.0 mA - - 0.36 - 0.44 - 0.55 V VOL IOZ OFF-state output current VI = VCC or GND; VCC = 5.5 V - - 0.25 - 2.5 - 10 μA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 μA ΔICC additional supply current per input pin; VI = 3.4 V; other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 1.5 10 - 10 - 10 pF 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; for test circuit see Fig. 7. Symbol Parameter Conditions 25 °C Min Typ [1] -40 °C to +85 °C -40 °C to +125 °C Max Min Max Min Max Unit 74AHC2G125 tpd ten tdis CPD propagation delay enable time disable time power dissipation capacitance nA to nY; see Fig. 5 [2] VCC = 3.0 V to 3.6 V; CL = 15 pF - 4.7 8.0 1.0 9.5 1.0 11.5 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 6.6 11.5 1.0 13.0 1.0 14.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 3.4 5.5 1.0 6.5 1.0 7.0 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 4.8 7.5 1.0 8.5 1.0 9.5 ns VCC = 3.0 V to 3.6 V; CL = 15 pF - 5.0 8.0 1.0 9.5 1.0 11.5 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 6.9 11.5 1.0 13.0 1.0 14.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 3.6 5.1 1.0 6.0 1.0 6.5 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 4.9 7.5 1.0 8.5 1.0 9.5 ns VCC = 3.0 V to 3.6 V; CL = 15 pF - 6.0 9.7 1.0 11.5 1.0 12.5 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 8.3 13.2 1.0 15.0 1.0 16.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 4.1 6.8 1.0 8.0 1.0 8.5 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 5.7 8.8 1.0 10.0 1.0 11.0 ns - 9 - - - - - pF VCC = 4.5 V to 5.5 V; CL = 15 pF - 3.4 5.5 1.0 6.5 1.0 6.5 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 4.8 7.5 1.0 8.5 1.0 8.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 3.9 5.1 1.0 6.0 1.0 6.0 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 5.1 7.5 1.0 8.5 1.0 8.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 4.5 6.8 1.0 8.0 1.0 8.0 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 6.1 8.8 1.0 10.0 1.0 10.0 ns - 11 - - - - - pF nOE to nY; see Fig. 6 nOE to nY; see Fig. 6 [2] [2] per buffer; CL = 50 pF; fi = 1 MHz; [3] VI = GND to VCC 74AHCT2G125 tpd ten tdis CPD [1] [2] [3] propagation delay enable time disable time power dissipation capacitance nA to nY; see Fig. 5 nOE to nY; see Fig. 6 nOE to nY; see Fig. 6 [2] [2] [2] per buffer; CL = 50 pF; fi = 1 MHz; [3] VI = GND to VCC Typical values are measured at Tamb = 25 °C and VCC = 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL; ten is the same as tPZL and tPZH; tdis is the same as tPLZ and tPHZ. CPD is used to determine the dynamic power dissipation PD (μW). 2 2 PD = CPD × VCC × fi + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 11.1. Waveforms and test circuit VI VM nA input GND tPHL tPLH VOH VM nY output VOL mna230 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. Input (nA) to output (nY) propagation delays VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs enabled outputs disabled mna362 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Enable and disable times Table 9. Measurement points Type Input Output VM VM VX VY 74AHC2G125 0.5VCC 0.5VCC VOL + 0.3 V VOH - 0.3 V 74AHCT2G125 1.5 V 0.5VCC VOL + 0.3 V VOH - 0.3 V 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RL RT S1 open CL 001aad983 Test data is given in Table 10. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 7. Test circuit for measuring switching times Table 10. Test data Type Input Load VI tr, tf CL 74AHC2G125 VCC ≤ 3 ns 74AHCT2G125 3V ≤ 3 ns 74AHC_AHCT2G125 Product data sheet S1 position RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 15 pF, 50 pF 1 kΩ open GND VCC 15 pF, 50 pF 1 kΩ open GND VCC All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 12. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 Fig. 8. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Package outline SOT505-2 (TSSOP8) 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 Fig. 9. References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Package outline SOT765-1 (VSSOP8) 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 13. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT2G125 v.4 20190102 Product data sheet - Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74AHC2G125GD and 74AHCT2G125GD (SOT996-2) removed. Package outline drawing SOT765-1 (VSSOP8) updated. 74AHC_AHCT2G125 v.3 20130506 Modifications: • 74AHC_AHCT2G125 v.2 20081222 Modifications: • • • 74AHC_AHCT2G125 v.1 74AHC_AHCT2G125 Product data sheet 74AHC_AHCT2G125 v.3 Product data sheet - 74AHC_AHCT2G125 v.2 For type number 74AHC2G125GD and 74AHCT2G125GD XSON8U has changed to XSON8. Product data sheet - 74AHC_AHCT2G125 v.1 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Added type number 74AHC2G125GD and 74AHCT2G125GD (XSON8U package). 20040113 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 - © Nexperia B.V. 2019. All rights reserved 10 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AHC_AHCT2G125 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 74AHC2G125; 74AHCT2G125 Nexperia Dual buffer/line driver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 2 7. Functional description................................................. 2 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................3 10. Static characteristics..................................................3 11. Dynamic characteristics.............................................5 11.1. Waveforms and test circuit........................................ 6 12. Package outline.......................................................... 8 13. Abbreviations............................................................ 10 14. Revision history........................................................10 15. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 January 2019 74AHC_AHCT2G125 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 2 January 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12
74AHC2G125GD,125 价格&库存
很抱歉,暂时无法提供与“74AHC2G125GD,125”相匹配的价格&库存,您可以联系我们找货
