CPE-503
CPE-503
    CUIDEVICES
    BUZZER PIEZO 12V 24 X10MM RADIAL
CPE-503 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/05/2022 page 1 of 3 MODEL: CPE-503 | DESCRIPTION: PIEZO BUZZER TRANSDUCER FEATURES • feedback pin • 12 Vdc rating • driving circuit • vertical orientation through hole mount • wide operating temperature range (-30~115 °C) SPECIFICATIONS parameter conditions/description min rated voltage max 12 operating voltage current consumption typ 3 at rated voltage rated frequency 2,700 sound pressure level at 30 cm, rated voltage dimensions 25.0 x 24.0 x 10.0 3,200 PC+10% glass (black) terminal pin type (Au plating) Vdc 28 Vdc 7 mA 3,700 72 Hz dB mm weight material units 3.7 g operating temperature -30 115 °C storage temperature -40 125 °C max units 380 °C 260 °C RoHS Notes: yes 1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted. SOLDERABILITY parameter conditions/description min hand soldering for maximun 5 seconds 330 wave soldering see wave soldering profile 6Tfd!Nby ijķı 3.6±D0Tfd! ŕŦŮűŦųŢŵŶųŦ Ʊń 311±D0Tfd! IJijı 3.6±D0Tfd! ijĶ ĵıŴŦŤ ķıŴŦŤġ IJııŴŦŤ 2/6Tfd!Nby őųŦũŦŢŵŪůŨ Ŏ ŦŭŵŪůŨ cuidevices.com ńŰŰŭŪůŨ ŕŪŮ ŦġŜŴŦŤŞ typ Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CPE-503 | DESCRIPTION: PIEZO BUZZER TRANSDUCER date 08/05/2022 | page 2 of 3 MECHANICAL DRAWING units: mm tolerance: ±0.5 mm 10.0 24.0 25.0 WWYY 5.5 M F (+) G (-) 3.2 0.8 (3 PLCS) 5.9 4.0 12.5 PERFORMANCE CURVES P: Voltage vs. Sound Pressure Level I: Voltage vs. Current Consumption at 30 cm DRIVING CIRCUIT Notes: 1. The current consumption and the sound pressure level are measured by using the recommend driving circuit shown above. cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CPE-503 | DESCRIPTION: PIEZO BUZZER TRANSDUCER date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 11/12/2007 1.01 applied new spec template 01/07/2016 1.02 brand update 11/20/2019 logo, datasheet style update 08/05/2022 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CPE-503 价格&库存
很抱歉,暂时无法提供与“CPE-503”相匹配的价格&库存,您可以联系我们找货
