74AUP1T1326GT,115
74AUP1T1326GT,115
    NEXPERIA(安世)
    XSON8
    IC BUFFER NON-INVERT 3.6V 8XSON
74AUP1T1326GT,115 数据手册
74AUP1T1326 Low-power dual supply buffer/line driver; 3-state Rev. 2.1 — 23 July 2018 1 Product data sheet General description The 74AUP1T1326 is a high-performance, low-power, low-voltage, single-bit, dual supply buffer/line driver with output enable circuitry. The 74AUP1T1326 is designed for logic-level translation applications and combines the functions of the 74AUP1G32 and 74AUP1G126. The buffer/line driver is controlled by two output enable Schmitt trigger inputs (1OE and 2OE) through an OR-gate. The output enable inputs accept standard input signals and are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. The output of the OR-gate is also available at output 1Y. The output enable inputs (1OE and 2OE) switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT- is defined as the input hysteresis voltage VH. Both VCC(A) and VCC(B) can be supplied at any voltage between 1.1 V and 3.6 V making the device suitable for interfacing between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V) with compatible input levels. Pins 1OE, 2OE and 1Y are referenced to VCC(A) and pins A and 2Y are referenced to VCC(B). A logic LOW on both output enable pins causes the output 2Y to assume a high-impedance OFF-state. The device ensures low static and dynamic power consumption and is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the outputs, preventing any damaging backflow current through the device when it is powered down. 2 Features and benefits • Wide supply voltage range: – VCC(A): 1.1 V to 3.6 V; VCC(B): 1.1 V to 3.6 V. • High noise immunity • Complies with JEDEC standards: – JESD8-7 (1.2 V to 1.95 V) – JESD8-5 (1.8 V to 2.7 V) – JESD8-B (2.7 V to 3.6 V) • ESD protection: – HBM JESD22-A114E Class 2A exceeds 2000 V – MM JESD22-A115-A exceeds 200 V – CDM JESD22-C101C exceeds 1000 V • Low static power consumption; ICC = 0.9 μA (maximum) • Latch-up performance exceeds 100 mA per JESD 78 Class II • Inputs accept voltages up to 3.6 V • Low noise overshoot and undershoot < 10 % of VCC • IOFF circuitry provides partial Power-down mode operation 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state • Multiple package options • Specified from -40 °C to +85 °C 3 Ordering information Table 1. Ordering information Type number 74AUP1T1326GT 4 Package Temperature range Name Description Version -40 °C to +85 °C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1 × 1.95 × 0.5 mm Marking Table 2. Marking Type number Marking code 74AUP1T1326GT p31 5 Functional diagram 1OE 5 7 Rpd 2OE 1Y 6 Rpd VCC(A) A 2 8 VCC(B) 2Y 001aaj293 Rpd = Internal pull-down resistor. Figure 1. Logic symbol 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 6 Pinning information 6.1 Pinning 74AUP1T1326 VCC(B) 1 8 2Y A 2 7 1Y VCC(A) 3 6 2OE GND 4 5 1OE 001aaj294 Transparent top view Figure 2. Pin configuration SOT833-1 (XSON8) 6.2 Pin description Table 3. Pin description Symbol Pin Description VCC(B) 1 supply voltage B A 2 data input VCC(A) 3 supply voltage A GND 4 ground (0 V) 1OE 5 output enable input (Schmitt trigger input) 2OE 6 output enable input (Schmitt trigger input) 1Y 7 data output 2Y 8 data output 7 Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Input Output 1OE 2OE A 1Y 2Y L L X L Z X H L H L X H H H H H X L H L H X H H H 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A -0.5 +4.6 V VCC(B) supply voltage B -0.5 +4.6 V IIK input clamping current VI IOK VO -50 - input voltage [1] -0.5 +4.6 V output clamping current VO > VCCO or VO < 0 V [2] - -50 mA Active mode and Power-down mode [1] -0.5 +4.6 V VO = 0 V to VCCO [2] - ±20 mA output voltage VI < 0 V mA IO output current ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 250 mW Ptot total power dissipation Tamb = -40 °C to +85 °C [3] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] VCCO is the supply voltage associated with an output pin. [3] For XSON8 package: above 45 °C the value of Ptot derates linearly with 2.4 mW/K. 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 1.1 3.6 V VCC(B) supply voltage B 1.1 3.6 V VI input voltage 0 3.6 V 0 VCCO V VO output voltage Tamb ambient temperature Δt/ΔV [1] input transition rise and fall rate -40 +85 °C input A; VCCI = 1.1 V to 3.6 V [2] - 200 ns/V input nOE; VCCI = 1.1 V to 3.6 V [2] - 30 ms/V [1] VCCO is the supply voltage associated with an output pin. [2] VCCI is the supply voltage associated with an input pin. 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 10 Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH HIGH-level input voltage Conditions Tamb = 25 °C LOW-level input voltage Min Typ Max Min Max VCCI = 1.1 V to 1.95 V 0.65VCCI - - 0.65VCCI - V VCCI = 2.3 V to 2.7 V 1.6 - - 1.6 - V 2.0 - - 2.0 - V VCCI = 1.1 V to 1.95 V - - 0.35VCCI - VCCI = 2.3 V to 2.7 V - - 0.7 - 0.7 V - - 0.9 - 0.9 V VCCO - 0.1 - - VCCO - 0.1 - V IO = -1.1 mA; VCCO = 1.1 V 0.825 - - 0.825 - V IO = -1.7 mA; VCCO = 1.4 V 1.05 - - 1.05 - V IO = -3 mA; VCCO = 1.65 V 1.2 - - 1.2 - V IO = -2.3 mA; VCCO = 2.3 V 1.97 - - 1.97 - V IO = -4.0 mA; VCCO = 2.3 V 2.0 - - 2.0 - V IO = -2.7 mA; VCCO = 3.0 V 2.67 - - 2.67 - V 2.48 - - 2.48 - V - - 0.10 - 0.10 V IO = 1.1 mA; VCCO = 1.1 V - - 0.275 - 0.275 V IO = 1.7 mA; VCCO = 1.4 V - - 0.35 - 0.35 V IO = 3.0 mA; VCCO = 1.65 V - - 0.45 - 0.45 V IO = 2.3 mA; VCCO = 2.3 V - - 0.33 - 0.33 V IO = 4.0 mA; VCCO = 2.3 V - - 0.40 - 0.40 V IO = 2.7 mA; VCCO = 3.0 V - - 0.33 - 0.33 V - - 0.40 - 0.40 V - - ±0.1 - ±0.5 μA - - ±0.1 - ±0.5 μA input A; [1] [2] input A; VCCI = 3.0 V to 3.6 V VOH HIGH-level VI = VIL or VI or VI = VT+ or VToutput voltage IO = -20 μA; VCCO = 1.1 V to 3.6 V LOW-level VI = VIL or VI or VI = VT+ or VToutput voltage IO = 20 μA; VCCO = 1.1 V to 3.6 V [3] IO = 6.0 mA; VCCO = 3.0 V II input leakage current IOZ OFF-state output 2Y; VI = VIH or VIL; output current VO = 0 V to 3.6 V; VCC(A) = 1.1 V to 3.6 V; VCC(B) = 1.1 V to 3.6 V 74AUP1T1326 Product data sheet input A; VI = 0 V to 3.6 V; VCCI = 1.1 V to 3.6 V 0.35VCCI V [3] IO = -6.0 mA; VCCO = 3.0 V VOL Unit [1] [2] VCCI = 3.0 V to 3.6 V VIL Tamb = -40 °C to +85 °C [1] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Unit Min Typ Max Min Max 1Y; VCC(A) = 0 V; VO = 0 V to 3.6 V; VCC(B) = 1.1 V to 3.6 V - - ±0.2 - ±0.5 μA A, 2Y; VCC(B) = 0 V; VI or VO = 0 V to 3.6 V; VCC(A) = 1.1 V to 3.6 V - - ±0.2 - ±0.5 μA additional power-off leakage current 1Y; VCC(A) = 0 V to 0.2 V; VO = 0 V to 3.6 V; VCC(B) = 1.1 V to 3.6 V - - ±0.2 - ±0.6 μA A, 2Y; VCC(B) = 0 V to 0.2 V; VI or VO = 0 V to 3.6 V; VCC(A) = 1.1 V to 3.6 V - - ±0.2 - ±0.6 μA ICC(A) supply current A VI = 0 V or VCC(A); IO = 0 A; VCC(A) = 1.1 V to 3.6 V; VCC(B) = 0 V to 3.6 V - - 0.5 - 0.9 μA ICC(B) supply current B VI = 0 V or VCC(B); IO = 0 A VCC(A) = VCC(B) = 1.1 V to 3.6 V - - 0.5 - 0.9 μA VCC(A) = 1.71 V; VCC(B) = 2.6 V - - 350 - 500 μA - - 40 - 50 μA - - 40 - 50 μA - - - - 1 μA 151 281 428 150 435 kΩ IOFF ΔIOFF ΔICC power-off leakage current additional nOE; VCC(A) = VCC(B) = 3.3 V; supply current VI = VCC(A) - 0.6 V A; VCC(A) = VCC(B) = 3.3 V; VI = VCC(B) - 0.6 V A; VI = GND to 3.6 V; nOE = GND; VCC(A) = VCC(B) = 1.1 V to 3.6 V Rpd pull-down resistance CI input capacitance CO [1] [2] [3] [4] output capacitance [4] input A; VI = 0 V or VCCI; VCCI = 1.1 V to 3.6 V [1] - 0.9 - - - pF input nOE; VI = 0 V or VCCI; VCCI = 1.1 V to 3.6 V [1] - 0.8 - - - pF 1Y; VO = GND; VCCO = 0 V [3] - 1.7 - - - pF 2Y enabled; VO = GND; VCCO = 0 V [3] - 1.7 - - - pF 2Y disabled; VCCO = 0 V to 3.6 V; VO = GND or VCCO [3] - 1.5 - - - pF VCCI is the supply voltage associated with the input pin. For VCCI values not specified in the data sheet: minimum VIH = 0.7 × VCCI and maximum VIL = 0.3 × VCCI. VCCO is the supply voltage associated with the output pin. To show ICC remains very low when the input-disable feature is enabled. 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 11 Transfer characteristics Table 8. Transfer characteristics Voltages are referenced to GND (ground = 0 V; for test circuit see Figure 9. Symbol Parameter VT+ VT- VH positive-going threshold voltage negative-going threshold voltage hysteresis voltage 74AUP1T1326 Product data sheet Conditions Tamb = 25 °C Tamb = -40 °C to +85 °C Unit Min Typ Max Min Max VCC(A) = 1.1 V 0.53 - 0.90 0.53 0.90 V VCC(A) = 1.4 V 0.74 - 1.11 0.74 1.11 V VCC(A) = 1.65 V 0.91 - 1.29 0.91 1.29 V VCC(A) = 2.3 V 1.37 - 1.77 1.37 1.77 V VCC(A) = 3.0 V 1.88 - 2.29 1.88 2.29 V VCC(A) = 1.1 V 0.26 - 0.65 0.26 0.65 V VCC(A) = 1.4 V 0.39 - 0.75 0.39 0.75 V VCC(A) = 1.65 V 0.47 - 0.84 0.47 0.84 V VCC(A) = 2.3 V 0.69 - 1.04 0.69 1.04 V VCC(A) = 3.0 V 0.88 - 1.24 0.88 1.24 V VCC(A) = 1.1 V 0.08 - 0.46 0.08 0.46 V VCC(A) = 1.4 V 0.18 - 0.56 0.18 0.56 V VCC(A) = 1.65 V 0.27 - 0.66 0.27 0.66 V VCC(A) = 2.3 V 0.53 - 0.92 0.53 0.92 V VCC(A) = 3.0 V 0.79 - 1.31 0.79 1.31 V nOE inputs; see Figure 3 and Figure 4 nOE inputs; see Figure 3 and Figure 4 nOE inputs; (VT+ - VT-); see Figure 3, Figure 4, Figure 5 and Figure 6 All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 11.1 Waveforms transfer characteristics VO VI VT+ VH VT- VO VI VH VT- VT+ mnb155 VT+ and VT- limits at 70 % and 20 %. mnb154 Figure 3. Transfer characteristic Figure 4. Definition of VT+, VT- and VH 001aad691 240 001aad692 1200 ICC (µA) ICC (µA) 160 800 80 400 0 0 0.4 0.8 1.2 1.6 VI (V) 2.0 Figure 5. Typical transfer characteristics; VCC(A) = 1.8 V 74AUP1T1326 Product data sheet 0 0 1.0 2.0 VI (V) 3.0 Figure 6. Typical transfer characteristics; VCC(A) = 3.0 V All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 12 Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 5 pF tpd propagation delay A to 2Y; see Figure 7 [2] VCC(B) = 1.1 V to 1.3 V 3.0 5.4 9.5 2.7 9.7 ns VCC(B) = 1.4 V to 1.6 V 2.4 3.8 5.7 2.1 6.1 ns VCC(B) = 1.65 V to 1.95 V 1.9 3.1 4.5 1.7 5.0 ns VCC(B) = 2.3 V to 2.7 V 1.5 2.3 3.4 1.3 3.8 ns VCC(B) = 3.0 V to 3.6 V 1.2 2.1 3.0 1.0 3.3 ns VCC(A) = 1.1 V to 1.3 V 3.4 5.6 9.3 3.2 9.5 ns VCC(A) = 1.4 V to 1.6 V 2.8 4.2 5.9 2.6 6.3 ns VCC(A) = 1.65 V to 1.95 V 2.4 3.5 4.9 2.2 5.3 ns VCC(A) = 2.3 V to 2.7 V 2.2 2.9 3.9 2.0 4.1 ns VCC(A) = 3.0 V to 3.6 V 1.9 2.6 3.4 1.8 3.7 ns VCC(B) = 1.1 V to 1.3 V 3.4 6.2 11.0 3.0 11.4 ns VCC(B) = 1.4 V to 1.6 V 2.7 4.4 6.6 2.4 7.1 ns VCC(B) = 1.65 V to 1.95 V 2.3 3.6 5.3 2.0 5.8 ns VCC(B) = 2.3 V to 2.7 V 1.8 2.8 4.1 1.5 4.5 ns VCC(B) = 3.0 V to 3.6 V 1.6 2.6 3.8 1.3 4.2 ns VCC(A) = 1.1 V to 1.3 V 3.7 6.4 10.8 3.4 11.1 ns VCC(A) = 1.4 V to 1.6 V 3.1 4.7 6.8 2.8 7.2 ns VCC(A) = 1.65 V to 1.95 V 2.9 4.0 5.6 2.5 6.1 ns VCC(A) = 2.3 V to 2.7 V 2.5 3.4 4.6 2.2 4.9 ns VCC(A) = 3.0 V to 3.6 V 2.3 3.1 4.1 2.1 4.5 ns nOE to 1Y; see Figure 7 CL = 10 pF tpd propagation delay A to 2Y; see Figure 7 [2] nOE to 1Y; see Figure 7 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 15 pF tpd propagation delay A to 2Y; see Figure 7 [2] VCC(B) = 1.1 V to 1.3 V 3.8 6.9 12.5 3.4 12.9 ns VCC(B) = 1.4 V to 1.6 V 3.2 4.9 7.5 2.8 8.1 ns VCC(B) = 1.65 V to 1.95 V 2.7 4.0 6.0 2.3 6.5 ns VCC(B) = 2.3 V to 2.7 V 2.2 3.2 4.8 1.8 5.3 ns VCC(B) = 3.0 V to 3.6 V 1.8 2.9 4.4 1.6 4.8 ns VCC(A) = 1.1 V to 1.3 V 4.2 7.2 12.4 3.8 12.7 ns VCC(A) = 1.4 V to 1.6 V 3.6 5.2 7.6 3.3 8.2 ns VCC(A) = 1.65 V to 1.95 V 3.1 4.5 6.3 2.7 6.9 ns VCC(A) = 2.3 V to 2.7 V 2.8 3.8 5.3 2.5 5.6 ns VCC(A) = 3.0 V to 3.6 V 2.5 3.5 4.8 2.3 5.2 ns VCC(B) = 1.1 V to 1.3 V 4.8 9.0 16.6 4.2 17.3 ns VCC(B) = 1.4 V to 1.6 V 4.0 6.3 9.8 3.4 10.6 ns VCC(B) = 1.65 V to 1.95 V 3.5 5.1 7.8 3.0 8.6 ns VCC(B) = 2.3 V to 2.7 V 2.7 4.2 6.2 2.4 6.8 ns VCC(B) = 3.0 V to 3.6 V 2.5 3.9 5.9 2.3 6.4 ns VCC(A) = 1.1 V to 1.3 V 5.1 9.2 16.4 4.6 17.1 ns VCC(A) = 1.4 V to 1.6 V 4.3 6.6 9.9 3.8 10.8 ns VCC(A) = 1.65 V to 1.95 V 4.0 5.6 8.1 3.5 8.9 ns VCC(A) = 2.3 V to 2.7 V 3.4 4.7 6.7 3.0 7.2 ns VCC(A) = 3.0 V to 3.6 V 3.3 4.4 6.2 3.0 6.7 ns 3.4 8.7 20.0 3.2 20.3 ns 2.8 7.0 15.6 2.5 15.8 ns VCC(B) = 1.1 V to 1.3 V 3.4 7.1 15.2 3.2 15.5 ns VCC(B) = 1.4 V to 1.6 V 2.8 6.1 13.5 2.5 13.9 ns nOE to 1Y; see Figure 7 CL = 30 pF tpd propagation delay A to 2Y; see Figure 7 [2] nOE to 1Y; see Figure 7 CL = 5 pF; VCC(A) = 1.1 V to 1.3 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V VCC(B) = 1.4 V to 1.6 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 5 pF; VCC(A) = 1.4 V to 1.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 3.4 7.8 16.6 3.1 17.1 ns VCC(B) = 1.4 V to 1.6 V 2.8 6.1 12.2 2.5 12.6 ns 2.4 5.4 10.7 2.1 11.1 ns VCC(B) = 1.1 V to 1.3 V 3.4 6.3 11.8 3.1 12.3 ns VCC(B) = 1.4 V to 1.6 V 2.8 5.3 10.1 2.5 10.7 ns VCC(B) = 1.65 V to 1.95 V 2.4 5.4 9.9 2.1 10.5 ns VCC(B) = 1.1 V to 1.3 V 3.4 7.4 15.6 3.1 16.0 ns VCC(B) = 1.4 V to 1.6 V 2.8 5.6 11.2 2.5 11.5 ns VCC(B) = 1.65 V to 1.95 V 2.4 4.9 9.7 2.1 10.1 ns 2.2 4.4 8.2 1.9 8.8 ns VCC(B) = 1.1 V to 1.3 V 3.4 6.0 10.8 3.1 11.2 ns VCC(B) = 1.4 V to 1.6 V 2.8 5.0 9.1 2.5 9.6 ns VCC(B) = 1.65 V to 1.95 V 2.4 5.1 8.9 2.1 9.4 ns VCC(B) = 2.3 V to 2.7 V 2.2 4.3 7.8 1.9 8.4 ns VCC(B) = 1.1 V to 1.3 V 3.4 6.8 14.6 3.1 14.9 ns VCC(B) = 1.4 V to 1.6 V 2.8 5.0 10.1 2.5 10.4 ns VCC(B) = 1.65 V to 1.95 V 2.4 4.3 8.7 2.1 9.0 ns VCC(B) = 2.3 V to 2.7 V 2.2 3.7 7.2 1.9 7.7 ns 1.9 3.6 6.8 1.6 7.3 ns VCC(B) = 1.1 V to 1.3 V 3.4 5.5 9.8 3.1 10.1 ns VCC(B) = 1.4 V to 1.6 V 2.8 4.5 8.1 2.5 8.5 ns VCC(B) = 1.65 V to 1.95 V 2.4 4.6 7.9 2.1 8.3 ns VCC(B) = 2.3 V to 2.7 V 2.2 3.9 6.8 1.9 7.3 ns VCC(B) = 3.0 V to 3.6 V 1.9 4.4 7.3 1.6 7.7 ns VCC(B) = 1.65 V to 1.95 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 5 pF; VCC(A) = 1.65 V to 1.95 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 2.3 V to 2.7 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 5 pF; VCC(A) = 2.3 V to 2.7 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 3.0 V to 3.6 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 5 pF; VCC(A) = 3.0 V to 3.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 3.4 6.5 14.2 3.1 14.4 ns VCC(B) = 1.4 V to 1.6 V 2.8 4.8 9.7 2.5 9.9 ns VCC(B) = 1.65 V to 1.95 V 2.4 4.1 8.2 2.1 8.5 ns VCC(B) = 2.3 V to 2.7 V 2.2 3.4 6.7 1.9 7.2 ns 1.9 3.2 6.3 1.6 6.8 ns VCC(B) = 1.1 V to 1.3 V 3.4 5.3 9.3 3.1 9.7 ns VCC(B) = 1.4 V to 1.6 V 2.8 4.3 7.7 2.5 8.0 ns VCC(B) = 1.65 V to 1.95 V 2.4 4.4 7.4 2.1 7.9 ns VCC(B) = 2.3 V to 2.7 V 2.2 3.7 6.4 1.9 6.8 ns VCC(B) = 3.0 V to 3.6 V 1.9 4.2 6.9 1.6 7.2 ns 3.7 9.9 22.9 3.3 23.1 ns 3.1 8.0 17.8 2.8 18.1 ns VCC(B) = 1.1 V to 1.3 V 3.7 8.5 18.0 3.3 18.3 ns VCC(B) = 1.4 V to 1.6 V 3.1 7.3 16.0 2.8 16.4 ns VCC(B) = 1.1 V to 1.3 V 3.7 8.8 18.8 3.3 19.3 ns VCC(B) = 1.4 V to 1.6 V 3.1 6.9 13.8 2.8 14.2 ns 2.9 6.1 12.2 2.5 12.9 ns VCC(B) = 1.1 V to 1.3 V 3.7 7.6 14.0 3.3 14.5 ns VCC(B) = 1.4 V to 1.6 V 3.1 6.4 11.9 2.8 12.5 ns VCC(B) = 1.65 V to 1.95 V 2.9 6.7 12.0 2.5 12.6 ns VCC(B) = 3.0 V to 3.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 10 pF; VCC(A) = 1.1 V to 1.3 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V VCC(B) = 1.4 V to 1.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 10 pF; VCC(A) = 1.4 V to 1.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.65 V to 1.95 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 10 pF; VCC(A) = 1.65 V to 1.95 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 3.7 8.3 17.6 3.3 18.1 ns VCC(B) = 1.4 V to 1.6 V 3.1 6.4 12.6 2.8 13.1 ns VCC(B) = 1.65 V to 1.95 V 2.9 5.6 11.0 2.5 11.7 ns 2.5 5.1 9.7 2.2 10.5 ns VCC(B) = 1.1 V to 1.3 V 3.7 7.2 12.8 3.3 13.4 ns VCC(B) = 1.4 V to 1.6 V 3.1 6.0 10.8 2.8 11.4 ns VCC(B) = 1.65 V to 1.95 V 2.9 6.3 10.8 2.5 11.5 ns VCC(B) = 2.3 V to 2.7 V 2.5 5.2 9.5 2.2 10.1 ns VCC(B) = 1.1 V to 1.3 V 3.7 7.7 16.6 3.3 16.9 ns VCC(B) = 1.4 V to 1.6 V 3.1 5.8 11.6 2.8 11.9 ns VCC(B) = 1.65 V to 1.95 V 2.9 5.0 10.0 2.5 10.5 ns VCC(B) = 2.3 V to 2.7 V 2.5 4.4 8.7 2.2 9.3 ns 2.3 4.3 8.3 2.1 8.8 ns VCC(B) = 1.1 V to 1.3 V 3.7 6.8 11.8 3.3 12.2 ns VCC(B) = 1.4 V to 1.6 V 3.1 5.6 9.7 2.8 10.2 ns VCC(B) = 1.65 V to 1.95 V 2.9 5.9 9.8 2.5 10.3 ns VCC(B) = 2.3 V to 2.7 V 2.5 4.8 8.4 2.2 8.9 ns VCC(B) = 3.0 V to 3.6 V 2.3 5.8 9.4 2.1 9.8 ns VCC(B) = 2.3 V to 2.7 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 10 pF; VCC(A) = 2.3 V to 2.7 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 3.0 V to 3.6 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 10 pF; VCC(A) = 3.0 V to 3.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 3.7 7.4 16.1 3.3 16.5 ns VCC(B) = 1.4 V to 1.6 V 3.1 5.5 11.1 2.8 11.5 ns VCC(B) = 1.65 V to 1.95 V 2.9 4.7 9.5 2.5 10.1 ns VCC(B) = 2.3 V to 2.7 V 2.5 4.1 8.3 2.2 8.8 ns 2.3 3.9 7.8 2.1 8.3 ns VCC(B) = 1.1 V to 1.3 V 3.7 6.6 11.3 3.3 11.7 ns VCC(B) = 1.4 V to 1.6 V 3.1 5.4 9.3 2.8 9.7 ns VCC(B) = 1.65 V to 1.95 V 2.9 5.7 9.4 2.5 9.8 ns VCC(B) = 2.3 V to 2.7 V 2.5 4.6 8.0 2.2 8.5 ns VCC(B) = 3.0 V to 3.6 V 2.3 5.6 9.0 2.1 9.4 ns 4.2 10.9 25.5 3.8 25.9 ns 3.6 8.9 20.1 3.2 20.6 ns VCC(B) = 1.1 V to 1.3 V 4.2 9.9 20.8 3.8 21.1 ns VCC(B) = 1.4 V to 1.6 V 3.6 8.4 18.4 3.2 18.9 ns VCC(B) = 1.1 V to 1.3 V 4.2 9.7 20.8 3.8 21.4 ns VCC(B) = 1.4 V to 1.6 V 3.6 7.6 15.3 3.2 16.1 ns 3.1 6.8 13.6 2.7 14.5 ns VCC(B) = 1.1 V to 1.3 V 4.2 8.9 16.0 3.8 16.6 ns VCC(B) = 1.4 V to 1.6 V 3.6 7.4 13.7 3.2 14.4 ns VCC(B) = 1.65 V to 1.95 V 3.1 8.0 14.1 2.7 14.8 ns VCC(B) = 3.0 V to 3.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 15 pF; VCC(A) = 1.1 V to 1.3 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V VCC(B) = 1.4 V to 1.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 15 pF; VCC(A) = 1.4 V to 1.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.65 V to 1.95 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 15 pF; VCC(A) = 1.65 V to 1.95 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 4.2 9.1 19.5 3.8 20.1 ns VCC(B) = 1.4 V to 1.6 V 3.6 7.0 14.0 3.1 14.7 ns VCC(B) = 1.65 V to 1.95 V 3.1 6.2 12.2 2.7 13.2 ns 2.8 5.6 11.0 2.4 11.8 ns VCC(B) = 1.1 V to 1.3 V 4.2 8.5 14.7 3.8 15.3 ns VCC(B) = 1.4 V to 1.6 V 3.6 7.0 12.4 3.1 13.1 ns VCC(B) = 1.65 V to 1.95 V 3.1 7.5 12.7 2.7 13.5 ns VCC(B) = 2.3 V to 2.7 V 2.8 6.1 11.0 2.4 11.8 ns VCC(B) = 1.1 V to 1.3 V 4.2 8.5 18.4 3.8 18.8 ns VCC(B) = 1.4 V to 1.6 V 3.6 6.4 13.0 3.2 13.5 ns VCC(B) = 1.65 V to 1.95 V 3.1 5.6 11.2 2.7 11.9 ns VCC(B) = 2.3 V to 2.7 V 2.8 4.9 10.0 2.5 10.6 ns 2.5 4.8 9.6 2.3 10.1 ns VCC(B) = 1.1 V to 1.3 V 4.2 8.0 13.6 3.8 14.0 ns VCC(B) = 1.4 V to 1.6 V 3.6 6.6 11.3 3.2 11.8 ns VCC(B) = 1.65 V to 1.95 V 3.1 7.1 11.7 2.7 12.3 ns VCC(B) = 2.3 V to 2.7 V 2.8 5.7 10.0 2.5 10.5 ns VCC(B) = 3.0 V to 3.6 V 2.5 7.1 11.5 2.3 11.9 ns VCC(B) = 2.3 V to 2.7 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 15 pF; VCC(A) = 2.3 V to 2.7 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 3.0 V to 3.6 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 15 pF; VCC(A) = 3.0 V to 3.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 4.2 8.2 18.0 3.8 18.4 ns VCC(B) = 1.4 V to 1.6 V 3.6 6.1 12.5 3.2 13.0 ns VCC(B) = 1.65 V to 1.95 V 3.1 5.2 10.7 2.7 11.5 ns VCC(B) = 2.3 V to 2.7 V 2.8 4.6 9.5 2.5 10.1 ns 2.5 4.4 9.1 2.3 9.6 ns VCC(B) = 1.1 V to 1.3 V 4.2 7.8 13.2 3.8 13.6 ns VCC(B) = 1.4 V to 1.6 V 3.6 6.3 10.9 3.2 11.4 ns VCC(B) = 1.65 V to 1.95 V 3.1 6.9 11.3 2.7 11.8 ns VCC(B) = 2.3 V to 2.7 V 2.8 5.5 9.5 2.5 10.0 ns VCC(B) = 3.0 V to 3.6 V 2.5 6.8 11.0 2.3 11.5 ns 5.1 13.8 33.1 4.6 33.8 ns 4.3 11.2 26.1 3.8 27.7 ns VCC(B) = 1.1 V to 1.3 V 5.1 13.9 28.5 4.6 29.2 ns VCC(B) = 1.4 V to 1.6 V 4.3 11.7 25.4 3.8 26.2 ns VCC(B) = 1.1 V to 1.3 V 5.1 12.1 26.6 4.6 27.5 ns VCC(B) = 1.4 V to 1.6 V 4.3 9.5 19.6 3.8 21.4 ns 4.0 8.5 17.7 3.5 19.2 ns VCC(B) = 1.1 V to 1.3 V 5.1 12.6 22.0 4.6 22.9 ns VCC(B) = 1.4 V to 1.6 V 4.3 10.4 18.9 3.8 19.9 ns VCC(B) = 1.65 V to 1.95 V 4.0 11.6 20.1 3.5 21.2 ns VCC(B) = 3.0 V to 3.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 30 pF; VCC(A) = 1.1 V to 1.3 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V VCC(B) = 1.4 V to 1.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 30 pF; VCC(A) = 1.4 V to 1.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.65 V to 1.95 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 30 pF; VCC(A) = 1.65 V to 1.95 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 5.1 11.4 24.8 4.6 25.6 ns VCC(B) = 1.4 V to 1.6 V 4.3 8.7 17.8 3.8 19.5 ns VCC(B) = 1.65 V to 1.95 V 4.0 7.7 15.9 3.5 17.3 ns 3.4 7.1 14.3 3.1 15.3 ns VCC(B) = 1.1 V to 1.3 V 5.1 12.0 20.2 4.6 21.0 ns VCC(B) = 1.4 V to 1.6 V 4.3 9.9 17.1 3.8 18.0 ns VCC(B) = 1.65 V to 1.95 V 4.0 11.1 18.3 3.5 19.3 ns VCC(B) = 2.3 V to 2.7 V 3.4 8.7 15.5 3.2 16.4 ns VCC(B) = 1.1 V to 1.3 V 5.1 10.6 23.3 4.6 23.9 ns VCC(B) = 1.4 V to 1.6 V 4.3 7.9 16.4 3.8 17.8 ns VCC(B) = 1.65 V to 1.95 V 4.0 6.9 14.4 3.5 15.6 ns VCC(B) = 2.3 V to 2.7 V 3.4 6.2 12.8 3.2 13.6 ns 3.3 6.1 12.4 3.1 13.0 ns VCC(B) = 1.1 V to 1.3 V 5.1 11.5 18.7 4.6 19.3 ns VCC(B) = 1.4 V to 1.6 V 4.3 9.3 15.6 3.8 16.3 ns VCC(B) = 1.65 V to 1.95 V 4.0 10.5 16.8 3.5 17.5 ns VCC(B) = 2.3 V to 2.7 V 3.4 8.2 14.0 3.2 14.7 ns VCC(B) = 3.0 V to 3.6 V 3.3 10.7 17.0 3.1 17.6 ns VCC(B) = 2.3 V to 2.7 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 30 pF; VCC(A) = 2.3 V to 2.7 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 3.0 V to 3.6 V tdis disable time 74AUP1T1326 Product data sheet nOE to 2Y; see Figure 8 [4] All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Symbol Parameter Conditions Tamb = 25 °C Min Typ [1] Tamb = -40 °C to +85 °C Max Min Max Unit CL = 30 pF; VCC(A) = 3.0 V to 3.6 V ten enable time nOE to 2Y; see Figure 8 [3] VCC(B) = 1.1 V to 1.3 V 5.1 10.2 22.9 4.6 23.4 ns VCC(B) = 1.4 V to 1.6 V 4.3 7.6 15.9 3.8 17.2 ns VCC(B) = 1.65 V to 1.95 V 4.0 6.6 14.0 3.5 15.1 ns VCC(B) = 2.3 V to 2.7 V 3.4 5.8 12.4 3.2 13.1 ns 3.3 5.6 12.0 3.1 12.5 ns VCC(B) = 1.1 V to 1.3 V 5.1 11.2 18.3 4.6 18.8 ns VCC(B) = 1.4 V to 1.6 V 4.3 9.1 15.2 3.8 15.8 ns VCC(B) = 1.65 V to 1.95 V 4.0 10.2 16.4 3.5 17.0 ns VCC(B) = 2.3 V to 2.7 V 3.4 7.9 13.6 3.2 14.2 ns VCC(B) = 3.0 V to 3.6 V 3.3 10.5 16.5 3.1 17.1 ns VCC(A) = VCC(B) = 1.2 V - 2.8 - - - pF VCC(A) = VCC(B) = 1.5 V - 3.0 - - - pF VCC(A) = VCC(B) = 1.8 V - 3.0 - - - pF VCC(A) = VCC(B) = 2.5 V - 3.6 - - - pF VCC(A) = VCC(B) = 3.3 V - 4.1 - - - pF VCC(B) = 3.0 V to 3.6 V tdis disable time nOE to 2Y; see Figure 8 [4] CL = 5 pF, 10 pF, 15 pF and 30 pF CPD [1] [2] [3] [4] [5] power dissipation capacitance output 2Y; fi = 1 MHz; VI = 0 V to VCC [5] All typical values are measured at nominal VCC(A) and VCC(B). tpd is the same as tPLH and tPHL. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 18 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 12.1 Waveforms and test circuit VI nOE input VM VM tPLH tPHL GND VOH VM 1Y output VM VOL VI A input VM VM tPLH tPHL GND VOH VM 2Y output VM VOL 001aaj295 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Figure 7. Input nOE to output 1Y and A to output 2Y propagation delay times VI VM nOE input GND tPLZ 2Y output LOW-to-OFF OFF-to-LOW tPZL VCCO VM VX VOL tPHZ 2Y output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aaj296 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. VCCO is the supply voltage associated with the output pin. Output 1Y has no external load. Figure 8. Enable and disable times 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 19 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Table 10. Measurement points [1] Output [2] Supply voltage Input VCC(A), VCC(B) VM VM VX VY 1.1 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] VCCI is the supply voltage associated with the data input port. [2] VCCO is the supply voltage associated with the output port. VCC VI G DUT RT VEXT 5 kΩ VO CL RL 001aac521 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 9. Test circuit for measuring switching times Table 11. Test data Supply voltage Input [2] VCC(A), VCC(B) VI 1.1 V to 3.6 V VCCI [1] [2] [3] [4] Load [1] VEXT RL [3] tr = tf CL ≤ 3.0 ns 5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND [4] 2VCCO For measuring enable and disable times, CL and RL are connected to pin 2Y. Pin 1Y has no load. VCCI is the supply voltage associated with the data input port. For measuring enable and disable times RL = 5 kΩ, for measuring propagation delays RL = 1 MΩ. VCCO is the supply voltage associated with the output port. 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 20 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 13 Package outline XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Figure 10. Package outline SOT833-1 (XSON8) 74AUP1T1326 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 21 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 14 Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15 Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1T1326 v.2.1 20180723 Product data sheet - 74AUP1T1326 v.1 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74AUP1T1326 v.1 20090120 74AUP1T1326 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 - © Nexperia B.V. 2018. All rights reserved. 22 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state 16 Legal information 16.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74AUP1T1326 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 23 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74AUP1T1326 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2.1 — 23 July 2018 © Nexperia B.V. 2018. All rights reserved. 24 / 25 74AUP1T1326 Nexperia Low-power dual supply buffer/line driver; 3-state Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 12.1 13 14 15 16 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Transfer characteristics ......................................7 Waveforms transfer characteristics ....................8 Dynamic characteristics .....................................9 Waveforms and test circuit .............................. 19 Package outline .................................................21 Abbreviations .................................................... 22 Revision history ................................................ 22 Legal information .............................................. 23 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 July 2018 Document identifier: 74AUP1T1326
74AUP1T1326GT,115 价格&库存
很抱歉,暂时无法提供与“74AUP1T1326GT,115”相匹配的价格&库存,您可以联系我们找货
