Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 3
MODEL: CPE-353 | DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• wire leads with panel-mount tabs
• 12 Vdc rating
• 2.8 kHz rated frequency slow pulse
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
3
at rated voltage
rated frequency
2,300
sound pressure level
at 30 cm, rated voltage
81
tone
slow pulse at rated voltage
1.2
dimensions
Ø41.8 x 16.0
material
ABS UL94 1/16” HB High Heat (black)
terminal
wire leads
operating temperature
storage temperature
Notes:
2,800
units
Vdc
28
Vdc
8
mA
3,300
Hz
dB
1.5
1.8
Hz
mm
weight
RoHS
max
12
operating voltage
current consumption
typ
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
cuidevices.com
14.6
g
-30
85
°C
-40
95
°C
Product Page
3D Model
CUI DEVICES | MODEL: CPE-353 | DESCRIPTION: PIEZO BUZZER INDICATOR
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
3.4
(2 PLCS)
5.0
UL1007 LF 24AWG
5.0
2.0
60.0
black
red
140.0
41.8
50.0
5.0
16.0
PERFORMANCE CURVES
P: Voltage vs. Sound Pressure Level
I: Voltage vs. Current Consumption
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
11/12/2007
1.01
brand update
11/04/2019
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPE-353”相匹配的价格&库存,您可以联系我们找货
