Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 3
MODEL: CPE-260H | DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• wire leads with panel-mount tabs
• 12 Vdc rating
• 3.5 kHz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
current consumption
typ
8
at rated voltage
rated frequency
3,000
sound pressure level
at 30 cm, rated voltage
dimensions
Ø32.0 x 13.5
3,500
units
Vdc
16
Vdc
12
mA
4,000
92
Hz
dB
mm
weight
material
ABS UL94 1/16” HB High Heat (black)
terminal
wire leads
10.0
g
operating temperature
-30
85
°C
storage temperature
-40
95
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
cuidevices.com
Product Page
3D Model
CUI DEVICES | MODEL: CPE-260H | DESCRIPTION: PIEZO BUZZER INDICATOR
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
4.0
3.5
UL1095 LF 28AWG
5.0
2.0
red
black
140.0
44.0
32.0
38.0
5.0
13.5
PERFORMANCE CURVES
P: Voltage vs. Sound Pressure Level
I: Voltage vs. Current Consumption
cuidevices.com
1.0
Product Page
3D Model
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
11/12/2007
1.01
applied new spec template
06/12/2015
1.02
internal IC changed reducing max input voltage
03/15/2019
1.03
brand update
11/15/2019
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPE-260H”相匹配的价格&库存,您可以联系我们找货
