SPECIFICATIONS
PARAMETERS
VALUES
UNIT
RATED VOLTAGE (SQUARE WAVE)
5
3~8
60
30 ± 5
80
2,400 ± 200
Vp-p
Vp-p
COIL RESISTANCE
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
RELEASED FROM ENGINEERING
REVISED MINIMUM SPL @ 10cm
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED SPECIFICATIONS
3/29/2007
5/16/2007
11/5/2007
11/8/2011
R.W.
B.R.
M.L.
mA
OHM
dBA
Hz
-40 ~ +85
°C
-50 ~ +95
°C
LCP
Sn PLATED BRASS
grams
0.6
5.5
8.5
1.5 SOUND
PORT
1.5
SMT-0824-TW
6L
-5V-R
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
THIS DOCUMENT CONTAINS DATA PROPRIETARY
TO PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
D
8.5
WASH TAB
1.5
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
SMT-0824-TW-5V-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
J.D.
3/29/2007
D.F.
4/2/2007
R.W.
4/2/2007
11/5/2007
SMT-0824-TW-5V-R
Transducer (Electro-Mech)
Edition
Sheet
1/1
很抱歉,暂时无法提供与“SMT-0824-TW-5V-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+46.238901+5.99946
- 10+35.3606610+4.58802
- 25+31.9147525+4.14092
- 50+29.5848050+3.83861
- 100+27.46062100+3.56300
- 250+23.52291250+3.05208
- 国内价格 香港价格
- 600+21.49563600+2.78904
- 1200+20.042881200+2.60055
- 1800+19.663121800+2.55128
