SPECIFICATIONS
PARAMETERS
RATED VOLTAGE
OPERATING VOLTAGE RANGE
RATED CURRENT (MAX)
MINIMUM SPL @ 10 CM
RESONANT FREQUENCY
TONE OR PULSE RATE
OPERATING TEMPERATURE
STORAGE TEMPERATURE
HOUSING MATERIAL
TERMINAL MATERIAL
WEIGHT
VALUES
UNITS
12
5 ~ 15
200
125
3,000 500
SIREN
-20 ~ +70
-30 ~ +80
ABS
LEAD WIRE
52.2
Vdc
Vdc
mA
dBA
Hz
0 pulse /sec
THIS DOCUMENT CONTAINS DATA
PROPRIETARY TO PROJECTS UNLIMITED, INC.
ANY USE OR REPRODUCTION, IN ANY FORM,
WITHOUT PRIOR WRITTEN PERMISSION OF
PROJECTS UNLIMITED, INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
RELEASED FROM ENGINEERING
6/29/2011
APPROVED
8
C
C
grams
38
22
3(2)
350
44
50
56.5
5
4
UL1007 AWG #24 {RED(+), BLACK(-)}
39
32.5
36
29
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
X-5735-LW350-S-2-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
6/29/2011
M.L.
6/30/2011
B.R.
Date
Drawn Date
6/30/2011 6/29/2011
X-5735-LW350-S-2-R
Indicator
Edition
Sheet
1/1
很抱歉,暂时无法提供与“X-5735-LW350-S-2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+77.85720
- 200+30.13200
- 500+29.07360
- 1000+28.54440
