06020SA (60 X 20L)
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
P−Q CURVE
Auto Restart/Polarity Protection
In H2O
(Pa)
.24
60
Insulation Resistance:
5000
N
10M Ω or over with a DC500V Megger
.20
50
4500
M
4000
Static Pressure
L
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
Ps
Expected Life
.16
40
.12
30
.08
K
3000
J
2500
2000
M
Failure Rate: 10%
DC Axial Fans
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
60°C
SPEED CURVE
.04
10
40,000 Hours (AA/EA)
Material
K
1500
N
1000
L
500
J
0.2
0.3
0.4
0.5
0.6
0.7
3.53 7.06 10.59 14.12 17.65 21.18 24.71
(m3/min)
CFM
Air Flow
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Ball Bearing
Lead Wire : UL3385, AWG26, +Red, -Black
Outline
11.82
Min 300
Panel Cut-Outs
inch
Units: (mm)
1.97
(50.0)
1.97± 0.3
(50.0. ± 0.3)
56
2. .0)
65
(φ
0.169
4-(ø4.3 ± 0.2)
Rotation
2.36± 0.3
(60.0. ± 0.5)
56
2. .0)
65
(φ
2.28
(58.0)
1.97
(50.0)
.169
(4 –φ4.3 )
2.28
(58.0)
1.97
(50.0)
.169
(4 – φ4.3 )
1.97
(50.0)
2.28
(58.0)
0.157
(4.0 ± 0.5)
1.97± 0.3
(50.0. ± 0.3)
2.28
(58.0)
INLET SIDE
AIR
NAME
PLATE
0.78
(20. ± 0.5)
2.36± 0.3
(60.0. ± 0.5)
OUTLET SIDE
Specifications
Rated
Operating
Voltage
Voltage
(V)
(V)
06020SA-12J-AA-00
12
6.0 ~ 13.8
0.05
0.58
2800
12.7
0.36
06020SA-12K-AA-00
12
6.0 ~ 13.8
0.05
0.58
3200
14.5
0.41
06020SA-12L-AA-00
12
6.0 ~ 13.8
0.06
0.72
3600
16.6
MODEL
Current
Input
Speed
Power
(A)*1 (W)*1
Max.
Max. Static
Air Flow
Pressure
(min-1)*1 CFM*1 (m3/min)*1 in H2O
Noise
Mass
(Pa)*1
(dB)*1 (g)
0.09
21.2
21.5
0.11
27.6
23.5
56
0.47
0.14
34.7
26.0
56
56
56
06020SA-12M-AA-00
12
6.0 ~ 13.8
0.08
0.96
4000
18.4
0.52
0.17
42.6
28.5
06020SA-12N-AA-00
12
6.0 ~ 13.8
0.09
1.08
4400
20.5
0.58
0.21
52.1
30.5
56
06020SA-24L-AA-00
24
9.0 ~ 27.6
0.05
1.20
3600
16.6
0.47
0.14
34.4
26.0
56
06020SA-24M-AA-00
24
9.0 ~ 27.6
0.06
1.44
4000
18.4
0.52
0.16
40.0
28.5
56
06020SA-24N-AA-00
24
9.0 ~ 27.6
0.07
1.68
4400
20.5
0.58
0.20
49.1
30.5
56
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
很抱歉,暂时无法提供与“06020SA-12N-AL-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+134.046161+17.41964
- 10+108.4214210+14.08964
- 25+98.8476625+12.84551
- 50+92.0015350+11.95584
- 120+84.99399120+11.04519
