MA3010H05C-RSR
MA3010H05C-RSR
    MECHATRONICSFANGROUP(机电一体化)
    FANAXIAL30X10MM5VDC
MA3010H05C-RSR 数据手册
1.18 ±0.01 (30 ±0.3) 0.39 ±0.01 (10 ±0.3) 0.95 ±0.01 (24 ±0.2) 4.0 STATIC PRESSURE - MM OF WATER DC AXIAL FANS MA3010 series 0.12 ±0.01 (3 ±0.1) 0.10 ±0.01 (2.5 ±0.3) 3.0 L M H 2.0 1.0 0 0.04 0.12 0.08 0.16 AIR FLOW (M3/MIN) (30 x 30 x 10 mm) 1.18 x 1.18 x 0.39 inches Construction: UL94V-0 PBT impeller & frame Bearing option: ball bearing or sleeve Connection: AWG 30, UL1007 lead wires Frame: ribbed Protection: Options: Airflow: Rated Operating Current Voltage Voltage Speed Air Volume Max. Static Pressure (H2 0) Sound Noise Weight mA RPM dbA g MA3010L 5 3 - 6.5 60 5,000 0.06 2.15 1.85 0.07 15 8 thermal MA3010M 5 3 - 6.5 70 7,000 0.09 3.17 2.64 0.11 21 8 tachometer output signal MA3010H 5 3 - 6.5 140 9,000 0.12 4.22 3.77 0.15 28 8 air intake over struts MA3010L 12 7 - 13.8 40 5,000 0.06 2.15 1.85 0.07 15 8 MA3010M 12 7 - 13.8 70 7,000 0.09 3.17 2.64 0.11 21 8 MA3010H 12 7 - 13.8 100 9,000 0.12 4.22 3.77 0.15 28 8 w w w.mechatronic s.com 12.15.14 Model No. V E - mail: S ales @ M echatronic s.com V Fa x : 425 -2 2 2- 515 5 Tel: 425 -2 2 2- 5 9 0 0 M³/Min. CFM 800-453-4569 MM INCH Cooling Simplified
MA3010H05C-RSR 价格&库存
很抱歉,暂时无法提供与“MA3010H05C-RSR”相匹配的价格&库存,您可以联系我们找货
