BG1203-B044-000-00
BG1203-B044-000-00
    NMBTECHNOLOGIESCORPORATION
    FAN BLOWER 120X32MM 12VDC WIRE
BG1203-B044-000-00 数据手册
12032GA (Ø120 X 32L) Legacy Part No. BG1203 NMBTC.COM / 248.919.2250 Characteristic Curves General Specifications Motor Protection: (Pa) In H2O 1.1 275 Auto Restart/Polarity Protection Insulation Resistance: 10M Ω or over with a DC500V Megger -10°C ~ +60°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) Ps Expected Life .8 200 225 .7 N M 175 .6 150 .5 L 125 .4 K 100 .3 .2 75 50 .1 Failure Rate: 10% 25°C 250 DC DCAxial Blowers Fans Static Pressure Dielectric Withstand Voltage: AC 700V 1s Allowable Ambient Temperature Range: 1.0 .9 25 0 100,000 Hours 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 3.5 Material 10.6 17.6 27.9 Air Flow 31.7 (m3/min) CFM Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Ball Bearing Lead Wire : UL1007, AWG24, +Red, -Black 4.13 (105 ± 0.3) 4.72 (120 ± 1) .30 (7.5) LOT No. DIE-CAV No. 2.56 (65 ± 0.3) .59 (15) 3.62 (92 ± 0.3) .29 (7.5) NAME PLATE 3.46 (88 ± 0.3) .30 (7.5) .29 (7.5) 3.62 (92 ± 0.3) AIR 4.13 (105 ± 0.3) 4.72 (120 ± 1) 2.16 (55) 2.4 (61 ± 0.5) ROTATION AIR 1.26 (32 ± 0.5) .08 (2 ± 0.2) 11.8 (300) min inch Units: (mm) .30(7.5) .87(22) Outline 3.54 (90 ± 0.3) 3.46 (88 ± 0.3) THROUGH HOLE .176 9 – (φ4.3 ± 0.3) Specifications MODEL LEGACY P/N Rated Operating Current Input Speed Voltage Voltage Power (V) (V) (A)*1 (W)*1 (min-1)*1 12032GA-12K-AA-00 BG1203-B042-000-00 12 6 ~ 13.8 0.30 3.60 12032GA-12L-AA-00 BG1203-B043-000-00 12 6 ~ 13.8 0.48 5.78 12032GA-12M-AA-00 BG1203-B044-000-00 12 6 ~ 13.8 0.65 12032GA-12N-AA-00 BG1203-B045-000-00 12 6 ~ 13.8 12032GA-24K-AA-00 BG1203-B052-000-00 24 12032GA-24L-AA-00 BG1203-B053-000-00 12032GA-24M-AA-00 BG1203-B054-000-00 12032GA-24N-AA-00 BG1203-B055-000-00 Rotation: Counterclockwise Max. Air Flow Max. Static Pressure Noise Mass CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1 1800 22.2 0.63 .40 100 41.5 270 2100 26.1 0.74 .58 145 46.5 270 7.80 2250 28.2 0.80 .70 175 48.5 270 0.93 11.16 2650 33.2 0.94 1.04 260 54.0 270 12 ~ 27.6 0.17 4.08 1800 22.2 0.63 .40 100 41.5 270 24 12 ~ 27.6 0.25 6.00 2100 26.1 0.74 .56 145 46.5 270 24 12 ~ 27.6 0.30 7.20 2250 28.2 0.80 .70 175 48.5 270 24 12 ~ 25.2 0.48 11.52 2650 33.2 0.94 1.04 260 54.0 270 *1: Average Values in Free Air Note: PWM/Locked Rotor/Tach Available (g) 2.3
BG1203-B044-000-00 价格&库存
很抱歉,暂时无法提供与“BG1203-B044-000-00”相匹配的价格&库存,您可以联系我们找货
