74ALVCH16952DGG,11
74ALVCH16952DGG,11
    NEXPERIA(安世)
    TSSOP56_14.1X6.2MM
    IC TXRX NON-INVERT 3.6V 56TSSOP
74ALVCH16952DGG,11 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74ALVCH16952 16-bit registered transceiver; 3-state Rev. 02 — 27 April 2006 Product data sheet 1. General description The 74ALVCH16952 consists of two sections, each containing a dual octal non-inverting registered transceiver. Two 8-bit back to back registers store data flowing in both directions between two bidirectional buses. Data applied to the inputs is entered and stored on the rising edge of the clock (nCPAB and nCPBA) provided that the clock enable (nCEAB and nCEBA) is LOW. The data is then present at the output buffers, but is only accessible when the output enable input (nOEAB and nOEBA) is LOW. Data flow from A inputs to B outputs is the same as for B inputs to A outputs. 2. Features n CMOS low-power consumption n Multibyte flow-through pinout architecture n Low inductance, multiple center power and ground pins for minimum noise and ground bounce n Direct interface with TTL levels n Output drive capability 50 Ω transmission lines at 85 °C n Complies with JEDEC standard JESD8-B 3. Quick reference data Table 1. Quick reference data GND = 0 V; Tamb = 25 °C; tr = tf = 2.5 ns. Symbol Parameter tPHL, tPLH Min Typ Max Unit nCPBA to nAn; nCPAB to nBn VCC = 3.3 V; CL = 50 pF - 3.2 - ns VCC = 2.5 V; CL = 30 pF - 3.2 - ns VCC = 3.3 V - 350 - MHz - 3.0 - pF - 30 - pF propagation delay fmax maximum input clock frequency Ci input capacitance CPD [1] Conditions power dissipation capacitance per buffer; VI = GND to VCC CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. [1] 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 4. Ordering information Table 2. Ordering information Type number DGG Package Temperature range Name Description Version −40 °C to +85 °C plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 TSSOP56 5. Functional diagram 1A0 1A1 1A2 1A3 1A4 1A5 1A6 1A7 1OEBA 1OEAB 1CEAB 5 52 6 51 8 49 9 48 10 47 12 45 13 44 14 43 56 1 3 54 2 1B0 2A0 1B1 2A1 1B2 2A2 1B3 2A3 1B4 2A4 1B5 2A5 1B6 2A6 1B7 2A7 55 1CEBA 1CPAB 1CPBA 2OEBA 2OEAB 2CEAB 2CEBA 2CPAB 2CPBA 15 42 16 41 17 40 19 38 20 37 22 36 23 34 24 33 2B0 2B1 2B2 2B3 2B4 2B5 2B6 2B7 29 28 26 31 27 30 001aae552 Fig 1. Logic symbol 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 2 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 1OEBA 1CEBA 1CPBA 1OEAB 1CEAB 1CPAB 56 54 55 1 3 2 29 2OEBA 31 2CEBA 30 2CPBA 28 2OEAB 26 2CEAB 27 2CPAB 1A0 5 1EN3 G1 1C5 EN4 G2 2C6 EN9 G7 7C11 EN10 G8 8C12 3 6D 1A1 1A2 1A3 1A4 1A5 1A6 1A7 2A0 51 8 49 9 48 10 47 12 45 13 44 14 43 15 2A2 2A3 2A4 2A5 2A6 2A7 1B0 4 6 9 42 11D 12D 2A1 52 5D 1B1 1B2 1B3 1B4 1B5 1B6 1B7 2B0 10 16 41 17 40 19 38 20 37 21 36 23 34 24 33 2B1 2B2 2B3 2B4 2B5 2B6 2B7 001aae550 Fig 2. IEC logic symbol VCC data input to internal circuit 001aad245 Fig 3. Bus hold circuit 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 3 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state CEAB CPAB OEAB CEBA CPBA OEBA Q A0 D CP Q D B0 CP 8 IDENTICAL CHANNELS TO 7 OTHER CHANNELS 001aae549 Fig 4. Schematic diagram (one section) 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 4 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 6. Pinning information 6.1 Pinning 74ALVCH16952 1OEAB 1 56 1OEBA 1CPAB 2 55 1CPBA 1CEAB 3 54 1CEBA GND 4 53 GND 1A0 5 52 1B0 1A1 6 51 1B1 VCC 7 50 VCC 1A2 8 49 1B2 1A3 9 48 1B3 1A4 10 47 1B4 GND 11 46 GND 1A5 12 45 1B5 1A6 13 44 1B6 1A7 14 43 1B7 2A0 15 42 2B0 2A1 16 41 2B1 2A2 17 40 2B2 GND 18 39 GND 2A3 19 38 2B3 2A4 20 37 2B4 2A5 21 36 2B5 VCC 22 35 VCC 2A6 23 34 2B6 2A7 24 33 2B7 GND 25 32 GND 2CEAB 26 31 2CEBA 2CPAB 27 30 2CPBA 2OEAB 28 29 2OEBA 001aae551 Fig 5. Pin configuration 6.2 Pin description Table 3. Symbol Pin description Pin Description 1OEAB 1 output enable input (active LOW) 1CPAB 2 clock pulse input (active rising edge) 1CEAB 3 clock enable input (active LOW) GND 4 ground (0 V) 1A0 5 data input or output 1A0 1A1 6 data input or output 1A1 VCC 7 supply voltage 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 5 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state Table 3. Pin description …continued Symbol Pin Description 1A2 8 data input or output 1A2 1A3 9 data input or output 1A3 1A4 10 data input or output 1A4 GND 11 ground (0 V) 1A5 12 data input or output 1A5 1A6 13 data input or output 1A6 1A7 14 data input or output 1A7 2A0 15 data input or output 2A0 2A1 16 data input or output 2A1 2A2 17 data input or output 2A2 GND 18 ground (0 V) 2A3 19 data input or output 2A3 2A4 20 data input or output 2A4 2A5 21 data input or output 2A5 VCC 22 supply voltage 2A6 23 data input or output 2A6 2A7 24 data input or output 2A7 GND 25 ground (0 V) 2CEAB 26 clock enable input (active LOW) 2CPAB 27 clock pulse input (active rising edge) 2OEAB 28 output enable input (active LOW) 2OEBA 29 output enable input (active LOW) 2CPBA 30 clock pulse input (active rising edge) 2CEBA 31 clock enable input (active LOW) GND 32 ground (0 V) 2B7 33 data input or output 2B7 2B6 34 data input or output 2B6 VCC 35 supply voltage 2B5 36 data input or output 2B5 2B4 37 data input or output 2B4 2B3 38 data input or output 2B3 GND 39 ground (0 V) 2B2 40 data input or output 2B2 2B1 41 data input or output 2B1 2B0 42 data input/output 2B0 1B7 43 data input or output 1B7 1B6 44 data input or output 1B6 1B5 45 data input or output 1B5 GND 46 ground (0 V) 1B4 47 data input or output 1B4 1B3 48 data input or output 1B3 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 6 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state Table 3. Pin description …continued Symbol Pin Description 1B2 49 data input or output 1B2 VCC 50 supply voltage 1B1 51 data input or output 1B1 1B0 52 data input or output 1B0 GND 53 ground (0 V) 1CEBA 54 clock enable input (active LOW) 1CPBA 55 clock pulse input (active rising edge) 1OEBA 56 output enable input (active LOW) 7. Functional description 7.1 Function table Table 4. Function table[1][2] Operating mode Control nOEAB Input nCEAB nCPAB Output nBn Hold L H X X NC NC Load and output enable L L ↑ L L L H H H Load and output disable H L L Z H H Z L ↑ [1] A-to-B data flow is shown; B-to-A data flow is similar, but uses signals nOEBA, nCEBA and nCPBA [2] H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH transition; X = don’t care; Z = high impedance OFF-state; NC = no change. 74ALVCH16952_2 Product data sheet nAn Internal nQn © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 7 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Min Max Unit −0.5 +4.6 V control pins [1] −0.5 +4.6 V data inputs [1] −0.5 VCC + 0.5 V [1] −0.5 VCC + 0.5 V IIK input clamping current VI < 0 V - −50 mA IOK output clamping current VO > VCC or VO < 0 V - ±50 mA IO output current VO = 0 V to VCC - ±50 mA ICC quiescent supply current - 100 mA IGND ground current - −100 mA Tstg storage temperature −65 +150 °C - 600 mW total power dissipation Ptot Tamb = −40 °C to +125 °C [2] [1] The input and output negative voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 55 °C. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage CL = 30 pF [1] 2.3 - 2.7 V CL = 50 pF [1] 3.0 - 3.6 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature in free-air −40 - +85 °C ∆t/∆V input transition rise and fall rate VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V [1] Maximum speed performance. 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 8 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit HIGH-state input voltage VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 2.0 1.5 - V LOW-state input voltage VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V HIGH-state output voltage VI = VIH or VIL IOH = −100 µA; VCC = 2.3 V to 3.6 V VCC − 0.2 VCC - V IOH = −6 mA; VCC = 2.3 V VCC − 0.3 VCC − 0.08 - V IOH = −12 mA; VCC = 2.3 V VCC − 0.6 VCC − 0.26 - V IOH = −12 mA; VCC = 2.7 V VCC − 0.5 VCC − 0.14 - V IOH = −12 mA; VCC = 3.0 V VCC − 0.6 VCC − 0.09 - V IOH = −24 mA; VCC = 3.0 V VCC − 1.0 VCC − 0.28 - V Tamb = −40 °C to +85 VIH VIL VOH °C[1] LOW-state output voltage VOL VI = VIH or VIL IOL = 100 µA; VCC = 2.3 V to 3.6 V - GND 0.20 V IOL = 6 mA; VCC = 2.3 V - 0.07 0.40 V IOL = 12 mA; VCC = 2.3 V - 0.15 0.70 V IOL = 12 mA; VCC = 2.7 V - 0.14 0.40 V - 0.27 0.55 V ILI input leakage current VCC = 2.3 V to 3.6 V; VI = VCC or GND IOL = 24 mA; VCC = 3.0 V - 0.1 5 µA IOZ off-state output current VCC = 2.7 V to 3.6 V; VI = VIH or VIL; VO = VCC or GND - 0.1 10 µA ICC quiescent supply current VCC = 2.3 V to 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 40 µA ∆ICC additional quiescent supply current VCC = 2.3 V to 3.6 V; VI = VCC − 0.6 V; IO = 0 A - 150 750 µA IBHL bus hold LOW sustaining current VCC = 2.3 V; VI = 0.7 V [2] 45 - - µA VCC = 3.0 V; VI = 0.8 V [2] 75 150 - µA VCC = 2.3 V; VI = 1.7 V [2] −45 - - µA VCC = 3.0 V; VI = 2.0 V [2] −75 −175 - µA 500 - - µA −500 - - µA - 3.0 - pF IBHH bus hold HIGH sustaining current IBHLO bus hold LOW overdrive current VCC = 3.6 V [2] IBHHO bus hold HIGH overdrive current VCC = 3.6 V [2] Ci input capacitance [1] Typical values are measured at Tamb = 25 °C. [2] Valid for data inputs of bus hold parts. 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 9 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Tamb = −40 °C to +85 tPHL, tPLH tPZH, tPZL tPHZ, tPLZ tW propagation delay nCPBA to nAn; nCPAB to nBn 3-state output enable time nOEBA to nAn; nOEAB to nBn 3-state output disable time nOEBA to nAn; nOEAB to nBn pulse width HIGH or LOW nCPAB; nCPBA tsu setup time nAn to nCPAB or nBn to nCPBA nCEAB to nCPAB or nCEBA to nCPBA th hold time nAn to nCPAB or nBn to nCPBA nCEAB to nCPAB or nCEBA to nCPBA fmax CPD Conditions Min Typ Max Unit VCC = 2.3 V to 2.7 V 1.0 3.2 4.1 ns VCC = 2.7 V 1.0 - 4.6 ns VCC = 3.0 V to 3.6 V 1.0 3.2 3.9 ns VCC = 2.3 V to 2.7 V 1.0 - 5.4 ns VCC = 2.7 V 1.0 - 5.3 ns VCC = 3.0 V to 3.6 V 1.0 - 4.4 ns VCC = 2.3 V to 2.7 V 1.0 - 5.3 ns VCC = 2.7 V 1.4 - 4.4 ns VCC = 3.0 V to 3.6 V 1.1 - 4.0 ns VCC = 2.3 V to 2.7 V 3.3 - - ns VCC = 2.7 V 3.3 - - ns VCC = 3.0 V to 3.6 V 3.3 - - ns VCC = 2.3 V to 2.7 V 1.7 - - ns VCC = 2.7 V 1.9 - - ns VCC = 3.0 V to 3.6 V 1.5 - - ns °C[1] maximum clock pulse frequency power dissipation capacitance see Figure 6 see Figure 8 see Figure 8 see Figure 6 see Figure 7 VCC = 2.3 V to 2.7 V 1.2 - - ns VCC = 2.7 V 1.0 - - ns VCC = 3.0 V to 3.6 V 1.0 - - ns see Figure 7 VCC = 2.3 V to 2.7 V 0.6 - - ns VCC = 2.7 V 0.6 - - ns VCC = 3.0 V to 3.6 V 0.8 - - ns VCC = 2.3 V to 2.7 V 1.1 - - ns VCC = 2.7 V 0.9 - - ns VCC = 3.0 V to 3.6 V 1.1 - - ns VCC = 2.3 V to 2.7 V 150 350 - MHz VCC = 2.7 V 150 350 - MHz VCC = 3.0 V to 3.6 V 150 350 - MHz - 30 - pF see Figure 6 per buffer; VI = GND to VCC 74ALVCH16952_2 Product data sheet [2] © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 10 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state [1] Typical values are measured at nominal supply voltage and at Tamb = 25 °C. [2] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = number of inputs switching; Σ(CL × VCC2 × fo) = sum of outputs. 12. Waveforms 1/f max VI input nCPBA or nCPAB VM VM VM 0V tW tW t PHL t PLH VOH output nAn or nBn VM VM VOL 001aae956 Measurements points are given in Table 9. VOL and VOH are typical voltage output drop that occur with the output load. Fig 6. Propagation delay clock input (nCPAB, nCPBA) to output (nBn, nAn), clock pulse width and maximum clock pulse frequency VI input nAn or nBn nCEAB nCEBA VM 0V th th t su t su VI input nCPAB or nCPBA VM 0V 001aae547 Measurements points are given in Table 9. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 7. Setup and hold times 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 11 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state VI input nOEAB nOEBA VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VOL VM VX tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs enabled outputs disabled 001aae548 Measurements points are given in Table 9. VOL and VOH are typical voltage output drop that occur with the output load. Fig 8. 3-state enable and disable time Table 9. Measurement points Supply voltage Input VCC VI VM Output VM VX VY 2.3 V to 2.7 V VCC 0.5 V 0.5 V VOL + 0.15 V VOH − 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH − 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH − 0.3 V 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 12 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 10. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistor. VEXT = Test voltage for switching times. Fig 9. Load circuitry for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr, tf Load 2.3 V to 2.7 V VCC 2.7 V 3.0 V to 3.6 V CL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.5 ns 50 pF 500 Ω open 2 × VCC GND 2.7 V 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74ALVCH16952_2 Product data sheet VEXT RL © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 13 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 13. Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 detail X 28 w M bp e 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 10. Package outline SOT364-1 (TSSOP56) 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 14 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 14. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test TTL Transistor-Transistor Logic 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVCH16952_2 20060427 Product data sheet - 74ALVCH16952_1 Modifications: 74ALVCH16952_1 (9397 750 04563) • The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors • The symbol of pin numbers 15, 16, 17, 19, 20, 21, 23 and 24 is rectified 19980901 Preliminary specification 74ALVCH16952_2 Product data sheet - - © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 15 of 17 74ALVCH16952 Philips Semiconductors 16-bit registered transceiver; 3-state 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.semiconductors.philips.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Philips Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Philips Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 16.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Philips Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Philips Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Philips Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Philips Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Philips Semiconductors accepts no liability for inclusion and/or use of Philips Semiconductors products in such equipment or applications and therefore such inclusion and/or use is for the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Philips Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.semiconductors.philips.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Philips Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For additional information, please visit: http://www.semiconductors.philips.com For sales office addresses, send an email to: sales.addresses@www.semiconductors.philips.com 74ALVCH16952_2 Product data sheet © Koninklijke Philips Electronics N.V. 2006. All rights reserved. Rev. 02 — 27 April 2006 16 of 17 Philips Semiconductors 74ALVCH16952 16-bit registered transceiver; 3-state 18. Contents 1 2 3 4 5 6 6.1 6.2 7 7.1 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 5 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 7 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 8 Recommended operating conditions. . . . . . . . 8 Static characteristics. . . . . . . . . . . . . . . . . . . . . 9 Dynamic characteristics . . . . . . . . . . . . . . . . . 10 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Koninklijke Philips Electronics N.V. 2006. All rights reserved. For more information, please visit: http://www.semiconductors.philips.com. For sales office addresses, email to: sales.addresses@www.semiconductors.philips.com. Date of release: 27 April 2006 Document identifier: 74ALVCH16952_2
74ALVCH16952DGG,11 价格&库存
很抱歉,暂时无法提供与“74ALVCH16952DGG,11”相匹配的价格&库存,您可以联系我们找货
