03510SS-12N-AT-00
03510SS-12N-AT-00
    NMBTECHNOLOGIESCORPORATION
    FAN35X10MM12VDCW/TACH
03510SS-12N-AT-00 数据手册
SLEEVE BEARING 03510SS-12x (35 X 10L) NMBTC.COM / 248.919.2250 Characteristic Curves Motor Protection: Auto Restart/Polarity Protection Insulation Resistance: (in H2O) Pa 0.24 60 10M Ω or over with a DC500V Megger Static Pressure Ps AC 700V 1s or AC 500V 1min Allowable Ambient Temperature Range: -10°C ~ +70°C (Operating) -40°C ~ +70°C (Storage) (non-condensing environment) 0.20 12,000 N 50 0.16 40 0.12 30 0.08 20 0.04 10 8,000 L 6,000 4,000 N 0 Expected Life 2,000 M 0 .05 .10 .15 .20 0 1.77 3.53 5.30 7.06 30,000 Hours (L10) m3/min (CFM) Air Flow Q Material Outline min 200 Casing : Plastic (Black) UL94V-0 Impeller : Plastic (Black) UL94V-0 Bearing : Sleeve Bearing Lead Wire : UL1061, AWG26, +Red, -Black, (Tach) White (7.87) 40°C 10,000 M L 0 (min-1) Speed Curve ROTATION 4- 3.2±0.3 AIR 3.2 4- NAME PLATE 35 . .4 6 0) 10±0.5 (.39) (1 29 (1.14) 33 (1.30) 35 . .4 6 0) (.126) (1 29 (1.14) 33 (1.30) (.126) 3.2 (1.14) 4- 35±0.5 Unit: mm (inch) 29±0.3 Panel Cut-Outs (1.38) (.094) 29±0.3 (1.14) 35±0.5 (1.38) Name Plate 29 29 LOT No. (1.14) 33 (1.30) (1.14) 33 (1.30) 7 MODEL INLET SIDE OUTLET SIDE 12V (A) DC (B) A (B) Current 0.07 0.08 0.11 EP 00 MADE IN +:RED, -:BLACK R VDE 94518 C CHINA or JAPAN or CAMBODIA US CE MARK cULus MARK VDE MARK Specifications MODEL (A) Model Name 03510SS-12L-AT 03510SS-12M-AT 03510SS-12N-AT FACTORY ID. 7:CHINA C:JAPAN U:CAMBODIA XXXXXXX Rated Operating Voltage Voltage Current Input (V) (V) (A)*1 (W)*1 Speed Power Max. Max. Static Air Flow Pressure (min-1)*1 (CFM) (m3/min) (in H2O) (Pa) Noise Mass (dB)*1 (g) 03510SS-12L-AT-00 12 6.0 ~ 13.2 0.04 0.48 7000 3.88 0.11 0.12 30.9 19.0 10.5 03510SS-12M-AT-00 12 6.0 ~ 13.2 0.05 0.60 8000 4.24 0.12 0.16 39.4 22.4 10.5 03510SS-12N-AT-00 12 6.0 ~ 13.2 0.07 0.84 10000 5.65 0.16 0.23 56.3 27.0 10.5 *1: Average Values in Free Air Note: Locked Rotor/Tach Available DC Axial Fans Dielectric Withstand Voltage: P-Q Curve Speed N General Specifications SLEEVE BEARING 03510SS-12x (35 X 10L) NMBTC.COM / 248.919.2250 TACHO Specification TACHOMETER SIGNAL 1. 2. OUTPUT CIRCUIT : OPEN COLLECTOR VCE max +15V Ic max 5mA R DC FAN INSIDE ALARM OUTPUT ALARM SIGNAL CIRCUIT -1 DC Axial Fans SPECIFICATION Absolute Maximum Ratings at Ta=25℃ VCE max : +15V Ic max : 5mA [VCE(sat)max = 0.5V]
03510SS-12N-AT-00 价格&库存
很抱歉,暂时无法提供与“03510SS-12N-AT-00”相匹配的价格&库存,您可以联系我们找货
03510SS-12N-AT-00
  • 1+85.294181+11.05575
  • 10+69.2500910+8.97613
  • 25+63.2085125+8.19303
  • 50+58.8627950+7.62974
  • 100+54.75115100+7.09679
  • 480+52.75504480+6.83806
库存:518
